Driveshaft help?
Discussion in 'Technical' started by gtpictor, Mar 21, 2010.
  1. gtpictor
    gtpictor Member
    chicago
    maverick
    Dose anyone have a part # for summit for a driveshaft that works for our cars?
  2. Jamie Miles
    Alto, GA
    I've had a few
    How do you know the driveshaft is the problem? Have you taken it to a shop and had it rebalanced? Have you replaced the u joints with the correct ones? A drive shaft is a drive shaft, it dosen't matter if it was from a 6 cylinder originally. There are people who have beat on the 6 cylinder shafts for years and years with built engines and manual transmissions and never had a problem.
  3. gtpictor
    gtpictor Member
    chicago
    maverick
    very tru but i wanted a lighter one anyways so i figure i get what i wanted anyways and hopefully fix the problem.
  4. gtpictor
    gtpictor Member
    chicago
    maverick
    balance the drive shaft and replced the u-joint no diffrence. joy....
  5. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i sheared a rear u joint on my 66 impala years ago, split it in half, luckly it didn't drop the driveshaft. drove it 300 miles before i finally found out what was going on. i was driving to little rock ar and finally pulled into a sears and had them replace it. car vibrated alot down the road. oh ya, i lost a little bit of transmission fluid also.
  6. PaulS
    Maybe its time to check the converter?
