duraspark conversion
Discussion in 'Technical' started by bartikus, May 16, 2006.
  1. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    thanks for the info's :thumbs2:
  2. mavman
    mavman Member
    Arkansas
    white wire
    Works great for a retard....for boost. Or just a high speed retard. Lots of uses fer it!
    I used it for a boost retard on my old '74 Turbo Maverick. Retarded 10 deg I think..and I had it hooked to a hobbs pressure switch in the intake that retarded it when pressure got to 8 psi. Worked great.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Maybe you could use it on a street/strip car...
    Put it on a switch.
    Retard the timing when running on the street with low octane fuel.
    Switch it off when you put race gas in and run at the strip.
    Or
    At what RPM would you recommend using it as a high speed retard?
    Run an RPM activated relay to turn it on at a preset rpm...
    I don't know how that would work, dumping 10 degrees all at once.
    Just a thought.
    Dave
