Dyno! 2,260hp 2,240tq!!!
Discussion in 'Drag Racing' started by maverick75, May 30, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    yeah i checked into that last year its only a $21,000 course:cry:
  2. eddie1975
    Martinsburg, WV
    sold
    im kinda surprised that the torque is so low on my dyno sim , a stock W puts out over 318lbs , of course its just a sim
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I suppose our modeling programs are pretty different...
    Here is what I got on this one.
    I put an exhaust on mine, but very free flowing.
    (I wish mine was easier to post. It's alot of work to show it here. Even then it doesn't look very good when posted. Graphics are great in the program.)
  4. jmgford
    jmgford Member
    Iowa
    Dang, only 456 HP! Well, I guess I will just have to live with it.
    Thanks for running that. I appreciate it!:tiphat:
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    This is my old setup & the new one that are being done now. Just want to compare to make sure i'm headed in the right direction. Thanks
    OLD SETUP
    600 Holley
    air gap intake
    gt40 iron heads
    1.6 roller rockers
    3.55 gears
    stock manifold
    comp ratio 8
    CompCam:31-418-4 custom grind flattapped
    Advertised Duration 270-4 int. / 280-4 exh.
    Duration @ .050 224 int. / 230 exh.
    Valve lift .501 int. /.512 exh.
    Lobe Separation Angle 108
    New set up
    650 holley hp
    air gap intake
    GT40 iron heads CNC ported 1.90 / 1.60 valves flowing 230 cfm int. / 175 cfm exh.
    1.7 roller rockers
    3.55 gears
    1 5/8 shorty headers
    comp ratio 9.5
    CompCam:35-425-8 Hyd. roller
  6. ratio411
    ratio411 Member
    Pensacola
    Hey, I was playing with my program, so I threw this in.
    I need a great deal more info, but I just filled in the blanks with standard stuff, and left the variables the same for both tests.
    Also, I have a zillion Comp grinds, but they are not by part number.
    So, I just threw in a 281HR, which is fairly aggressive, but probably not the cam you have.
    Here is what I came up with, using limited info and filling in blanks.
  7. loki1911
    loki1911 Lucky
    Milton, WA
    '73 Maverick soon to be grabber clone
    hey ratio i also have engine analyzer but i have 3.3 and im still trying to figure it out but what do you get with my setup that i listed earlier, seeing if it compares at all with the numbers i got
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Dave, what other info you might need? I was thinking I would be around the 350 hp range. I may not have a choice but to go with aftermarket heads. Dont know if it makes a dofference but I do have 2 1/2 exhast with MAC flowpath mufflers. I NEED MORE POWER PLEASE. There's never enough hp but I need more.:hmmm:
  9. ratio411
    ratio411 Member
    Pensacola
    Here's what I come up with...
    Edit:
    For giggles, I threw a Vic JR intake on... seeing as how you don't make power to 3k anyway.
    It slaughtered the RPM after 3k.
    20 lbs more torque and 30 more hp... throughout the 3000 to 6500 band.
  10. loki1911
    loki1911 Lucky
    Milton, WA
    my numbers were way way different than that i got 393 ft/lbs@5500 and 439 hp@6000 and averages were 346 ft/lbs and 317 hp
  11. ratio411
    ratio411 Member
    Pensacola
    :yikes: Wow!
    Those are huge numbers for a 306...
    Does your version have all the specs built in?
    Mine has an extensive list of any kind of aftermarket part you can think of.
    For yours all I had to do was pull down each menu and click the part you have. Your exact head, intake, carb, cam, and all were in there.
    The only part that wasn't in the menus by brand name and factory spec was the 6901s. However "long tube header, 1 5/8" primary, 34" long tubes" is in my menu, which matches.
    So there was no 'ad libbing' on my part.
    I think the numbers I got are much more in line with a 306 and those parts. IMO you would need much more radical parts and more rpm to make 439/393 with such small cubes.:huh:
    Never know though...
  12. loki1911
    loki1911 Lucky
    Milton, WA
    thats what i thought too i had to do a lot of inputting of numbers on my parts but all the numbers i put in i looked up factory specs for the parts:hmmm:
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Try mine and see what it does:
    85 302 T Bird stock block and heads
    Crane H-272-2 cam 484 & 512 lift, 272 & 284 adv duration, duration @ .050 tappet =216 & 228
    Offy 360 intake [single plane]
    Holley 600 carb [vac sec]
    Hooker 6901 headers
  14. Scotty P
    Scotty P Member
    santa rosa, ca
    My turn? 1968 302 .030 over, 10.25 comp, Comp cam 282s, edelbrock rpm's, speed demon 650, long tube 1 5/8, Scott
  15. codycr6
    codycr6 Member
    combo?
    Since my combo is a little different, would you mind trying it?
    .040 over 302, 308 inches, stock crank and rods, balanced
    flat tops, 10:1 compression
    1971 351 Windsor heads, heavily ported and epoxied by Bennett Racing, probably one of the most heavily worked set of old Windsors around, 1.94/1.60 valves, double springs
    Lunati custom cam, 230/240@.050, 280/290 advertised, .523/.555 lift, 108 lobe seperation.
    1.6 Harland Sharp roller rockers
    Edelbrock Performer RPM, 750 Holley, 2 inch four hole spacer
    1 3/4 Hooker Super Comps, Jet Hot Coated, dual 3 inch exhaust, no bends.
    Full MSD ignition, distributor, coil, and digital 6
    Any other information needed?
