EFI conversion project . . .
Discussion in 'Technical' started by mashori, Sep 2, 2011.
  1. Bryant
    a set of spark plug wires for the coil pack. the explorer oil pump drive/cam sensor assembly. we will also need some sort of air intake pipe and filter set up.
  2. Bryant
    did you get the coil packs too?
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Need to wait on next paycheck for those. But on the to do list.
  4. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    If it counts for anything a good comparison between Mo's kit and mine is his came in a big pile in the box...
    When I pulled mine out of the box it looked like this :cry:[​IMG]
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Oh wow you put yours together yourself? Impressive
  6. markso125
    markso125 Member
    Lewiston Ut
    Yes I did it was a very very time consuming and nerve wracking experience considering how much money I spent on all of it and how easy it is too screw it all up...:cry:
    Honestly I dont think I will even be 100% sure of it until I get it up and running in the car.. Even though everything passed on on the jimstim...
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Do I still need the explorer cam position sensor?
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  9. markso125
    markso125 Member
    Lewiston Ut
    You only need both sensors for SEFI. If you are going to use wasted spark then you only need one sensor.
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I will get the synchronizer just because I will need something to drive the oil pump. And I'll add the sensor on there later if I go with a sequential setup. Thanks.
  11. Dave B
    Crap, I just tossed that stuff off my Explorer motor.
  12. markso125
    markso125 Member
    Lewiston Ut
    Now that will just about tick you off wont it.:mad:
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Next week we will experiment with crank wheel placement. Bryant thinks we can put it on the crank spacer. I'm assuming we would need the crank wheel key'd somehow....
    This guy sells this on ebay....
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    what's this for?
  15. markso125
    markso125 Member
    Lewiston Ut
    Its the same thing, its just a different style crank wheel trigger.
    It uses an aluminum wheel and it has magnets/steel inserts in it to start the trigger cycle.
