efi eec-v conversion docs.
Discussion in 'Technical' started by bomrat, Oct 10, 2011.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i just cut and spliced all that crap out. worked great after that.
    had fun snakeing the wire down to the transmission, but it worked, all plugged in.
    fun part is stripping down the wired and retaping the loom.
  2. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    I'm pulling the eng and trans back out for easier access. but i know what your talking about i'm using heat shrink conectors with solder and it makes a nice weather resitance connection!
  3. bomrat
    bomrat Member
    i wouldn't pull out the engine and trans. what a pain to get that back in
    i dropped the trans x member to make it easier to get the wires back.
    took me 10 minutes to get the wires back.
  4. 70 maverick
    70 maverick Member
    Ajo, AZ
    1970 Ford Maverick, 76 Mav for parts
    here's some pics of my car, almost the same setup. Motor is from a 2000 exploder and i have a t5. looks a bit ugly in the pics since i have wires and whatnot everywhere and i now have a big puller fan not the pusher P2260043.jpg ill have to take some new pics now that its all cleaned up. if you have any questions pm me
  5. diddie
    diddie Member
    indiana
    Pulling the engine and trans out of a Maverick isn't that bad compaird to some of what i do in the field! just got through changing the engine on a newer model Audi A6 THAT was a PAIN!:Handshake And building the car is most of the fun for me!
  6. bomrat
    bomrat Member
    some of the parts needed. to do the swap
    lokar aode / 4r70w shift linkage (ACA-1808)
    lokar throttle cable (tc-1000u)
    fabricated throttle cable bracket
    upper radiator hose. dayco 81480 (90 degree bend to universal flex)
    electric fan controller (i picked up the spal fan-pwm-v3)
    16" electric fan ( spal fan )
    custom power steering hose (16mm x 1.5 O-ring to comet hose )
    custom a/c hoses (i will have these fabricated up by somebody)
    obd2 port and pins
    new transmission coolant lines.
    fabricated trans crossmember
    vss with manual speedo cable. ( duralast su1022 )
    new speedo cable (part number #4190 Performance Automotive and Transmission Center 888 8771008)
    oil dipstick for the front of engine
    modified timing cover to accept oil dipstick
  7. bomrat
    bomrat Member
    well, giving up on the eec-v conversion, ending up to be too much of a pain in the butt.
    just purchased the FAST ezefi MPFI retrofit kit and the ford sensor pack.
    also going to pick up the baumann tcu to run the 4r70w.
    removed the older ford ecu and wiring harness.
    installed most of the fast harness already. much easier thats for sure.
  8. Bryant
    megasqirt is making a transmission controller now. it may cost less than the baumann one
