Engine Instal
Discussion in 'Technical' started by Scotty P, Jun 1, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If you bolt it corner to corner ... doesn't it make it harder to tilt back and forth with the tranny mounted? I can see corner to corner working well with just an engine ...
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Dan never had a problem but then again I have never installed one alone. If I was installing it by myself, I would rather have a engine tilter with the 4 chain setup.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    didn't for me.
    thats the only way I have ever bolted to a engine hoist.
  4. dmhines
    Cumming, GA
    Well my ENGINE and TRANNY are IN! Two of use did it this morning .. pulled the old ... swapped the four speed to the new ... and dropped them back in!
  5. Earl Branham
    Lugoff, SC
    How cool is that!!! Glad you got it done. Didn't even have 5 drunks supervising!!!!!
  6. stmanser
    Davenport, Iowa
    i get great satisfaction when i change an engine....it just makes me so happy knowing that i can do something that 80% of the world cant do
  7. maverick1970
    Missouri
    So will it be running by Sundown?
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Sundown Sunday night!
  9. dmhines
    Cumming, GA
    I screwed up my distributor trying to install a Hardened Gear .. So .. it will be ready to start by Sunday ... except my new distributor won't be here until Tuesday ...
  10. maverick1970
    Missouri
    Bummer, what did you do to your distributor?
  11. dmhines
    Cumming, GA
    While I was banging the hardened gear onto the shaft (should really be pressed on I guess) .. the collar at the top of the shaft broke in two ... To replace the collar I would need to remove the gear. I trashed the original gear to get it off. I banged for a while on the hardened gear and that sucker won't budge ... and yes the pin is out! :)
    I ordered a Pertronix Flame-Thrower Billet Distributor ... except for the polish it looks pretty much stock right down to the cap ... I called Pertronix and it comes with a hardened gear already installed compatible with the 5.0 roller cam ... So I'll be saying goodbye to points ...
  12. maverick1970
    Missouri
    That's what I figured, there has to be an easier way like freezing the distributor and heating the gear at the same time.
    I didn't mess with mine on my current engine just bought and MSD distributor.
