Exhaust tubing
Discussion in 'Technical' started by maverick4925, Jul 30, 2014.
  1. maverick4925
    maverick4925 Rust, Rust and more Rust
    Amelia, Ohio
    1970 Ford Maverick
    What do you guys use that's fairly inexpensive and easy to get ahold of. I'm finding a lot of stuff at pep boys and autozone, but the 45 degree bends alone are 6-10 a piece and it's for dual exhaust. I need enough to run from right behind the diff out through the back. But I've tallied it up and after finding the angles at 6 different stores because they only carry so much 1 7-8 tube, it's coming out to almost 100 bucks. Just seems a bit much for something I could almost find scrap for.
  2. Dave B
    100 bucks, I guess you don't want to know what my exhaust cost.
  3. maverick4925
    Amelia, Ohio
    1970 Ford Maverick
    Hahaha I know what a real exhaust Cost, and I know what I'm going to spend for a nice exhaust, but I just want to be able to safely drive the car without inhaling exhaust everywhere I go. I'm just not anywhere near ready for a real good exhaust yet.
  4. bmcdaniel
    bmcdaniel Senile Member
    I order mine from Summit Racing.
  5. Pintony
    Pintony Member
    St louis
    Pinto
    I do not care how much it costs... I'm wondering how you found a shop that will still bend tubeing.....:bouncy:
  6. Craig Selvey
    Several shops around me still bend tubing. Worth the drive I would say.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Exhaust Tubing..
    Summit Racing has a complete line of "mandrel bends" online which allows you to go over the axles quite nicely. It involves some fitting , cutting , and tweaking
    but its worth the effort. We've done six cars like this and it increases the flow of exhaust since there are no " crimps" in the pipes ..If power is what you're seeking then I would recommend the hand fitting.
    Cometized
    (Chip)
  8. Pintony
    Pintony Member
    St louis
    Pinto
    All my favorite shops are gone....:huh:
  9. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    I used the 2.5" mandrel bent U-fit kit from flowmaster, Awesome kit with some cutting and welding!
