Filler Tube into Tank
Discussion in 'General Maverick/Comet' started by Renton5, Jun 11, 2016.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hello!
    I have a '71 Mav that I've had the gas tank cleaned. I've replaced the filler
    tube grommet, but now I can't seem to get the tube into the tank beyond
    the first half inch. It is the proper fitting grommet, just very snug--as it
    should be. Is there some lubricant I can use on the tube that won't affect
    the gas, or is this just one of those pushpushpushpush things?
    Thanks for your help Mav/Comet kin!
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I used Vaseline on it myself.
  3. Mavman72
    Vaseline/wd 40/ silicone lube...Any will do just fine...
    71gold likes this.
  4. lcrabtree
    lcrabtree Member
    Arkansas
    76 Maverick, 95 Mustang, 65 Cobra Replica
    I had to lower the tank down quite a bit to get my filler to go in.
    Lester
  5. Renton5
    Renton5 Member
    Van Nuys, CA
    Thank you all for your responses! So the WD40, Vaseline, or silicon lube won't contaminate the gas? Having a rebuilt carb, I'm very concerned about that.
    Thank you again!
    Renton5
    Daniel
  6. Paul Masson
    1971 Grabber
    Ford used to recommend 10w30 when lubricating gas tank grommets. It works and it won't contaminate the fuel...
  7. DocRoche
    DocRoche Member
    1973 Ford Maverick
    I used a combination of ATF and acetone in a spray bottle. Wiped of the access. Worked real good for me.
    SupermanEst1984 likes this.
  8. SupermanEst1984
    SupermanEst1984 Michael Myers
    Monroe, NC 28110
    '72 2 door Ford Maverick 250 6 Bangin' it
    I've heard tales of people actually adding a cap full of transmission to their gasoline back in the days to help lubricate their internals and such. lol. Idk if there's any benefits or functionality to that but just heard it from a few old school guys back in the day.
    OP it's just 1 of those things you have to just do it and get it done situations. A little wd-40 or liquid wrench won't hurt here .... I wouldn't glob vaseline on it but just enough to get it slick to slide in. These ol'gals need it from time to time :rofl2:
