Finally got the t5 setup in!! (for people who want to but are scarred read this)
Discussion in 'General Maverick/Comet' started by lynhrt210, May 21, 2012.
  1. Joe Dirt
    Do your self a favor and pick up a set of Remflex gaskets and you will never have a header leak i use them on turbo builds and they are awesome and affordable
  2. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    well heres videos of it instead of pictures cause hopefully itll show it better to some people,excuse the camera for shaking.
    this part 1...i accidentally cut it off lol
  3. justosac
    justosac Member
    sacramento
    1972 maverick
    nice video's. i also am in the 15 swap family. video and pics coming soon
  4. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Great question...
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    ABSOLUTELY.. those gaskets are awesome and I've been using them for years now without so much as a pinhole leak from any of them. Which of course makes them even better for computer controlled vehicles with custom exhausts. I still use loctite or locking fasteners for good measure.. but I do know that they stop a lot of loose bolts on race cars running on solid mounts.
    I also have a bud with TT Supra that sprays a 50 shot to help spool up and he has never blown a gasket running 16 lbs of boost.
    They also bend over backwards to get parts to you when time is at a premium.
    Only downside to them that I've ever run into is the extra thickness gained at the flange which can throw tight installs off enough to require clearancing or heat wrap to stop contact/heat soak into surrounding surfaces/parts. Well.. that and the fact that I always feek bad about having to replace perfectly sealed gaskets when I work on cars that have them. You can get by on ocassion with reusing them.. but typically they delaminate and need to be replaced because they are so fragile due to the layered construction.
    Highly recommended to anyone who doesn't do a lot of R&R of their exhausts.. or when finishing up a build that you don't want to monkey with for quite some time. (y)
  6. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    SWEET! I hope to pull my 302 and 3 speed out early next month and replace it with a T5. You're report is VERY ENCOURAGING!
  7. Danny Morrison
    Danny Morrison Member
    Martinsville, VA
    1972 Grabber
    I have been told that the transmission tunnel on the 1970 is smaller that the later years. Is that true? The reason I am asking is because I put a T5 in my 70 last night and when I jacked up the transmission to where the engine was level like before, the transmission hit the tunnel. I hated to do it, but I took a dye grinder and split the top of the tunnel and raised the tunnel about an inch or so. This did however, let my existing crossmember work by just turning it around, and my drive shaft has the same pitch as before also. Oh well. Just a little more metal fabrication.
  8. Danny Morrison
    Martinsville, VA
    1972 Grabber
    So everybody that is modifying their crossmember and lowering the transmission no longer has the engine level? Seems like that would screw up the way the oil returns in the engine. It looked to me like it was almost as easy to modify the tunnel, since I had the interior out, as to build a new cross member.
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    love my t5 setup with hydraulic clutch setup and a 12 pound aluminum flywheel :drive:
  10. Eliud71
    Eliud71 Member
    Puerto Rico
    comet 1971 5.o mustang engines 1990
    good1
    is good pictures!everibody in Puerto Rico!:drive:this swap !no parts here for maverick or comets in auto parts!i wait for 14 years for run my car because my medical problem,but i put my picures coming soon!(y)
  11. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Thank you!! And can't wait to see the pics :)
  12. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    If my car already came with manual transmission, do i haveto change the clutch setup in order to install a t5? Thx for the info!:tiphat:
  13. resthavenfarms
    resthavenfarms New Member
    72 Maverick
    I'm curious as well. I'm not much of a mechanic ;), and everything is a bit of a learning curve for me. My mav has been switched from a c4 auto over to a 4spd tranny that needs a rebuild, but I'd rather put in a t5, just didn't know how much trouble it would be. Any info would be appreciated; you'd be helping someone who can't much help themselves:rofl:
  14. 302-72-mav
    302-72-mav Member
    sactown CA
    Look At my threads You will find that I posted a lot of pictures and info about my t 5 swap
