Fire breathing Carb!!
Discussion in 'General Maverick/Comet' started by SERE Guy, Jun 23, 2009.
  1. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    This wasn't nearly as bad, or entertaining as my first backfire, where I perfect orb of fire shot out of the one barrel on the inline six of my old Mav. Of course I was leaned over it working the throttle, and lost some hair.
  2. darren
    Lesson learned.:)
    Back in high school one of my classmates was firing up a 350 Pontiac on a stand after a rebuild. He leaned over the engine to hit the throttle cause it wouldnt fire. It backfired bigtime and blew the air cleaner lid off and smoked him right in the face. Guess he should have put on the wing nut and timed it right. Damn funny.:):):):)
  3. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    That's WAAAAY more funny. I usually don't have the air cleaner on when I'm doing stuff like that, since it gets in the way. Now I have a whole new reason.
  4. Mavman72
    I lost an eyebrow to a lean backfire once...once...:p
  5. fordmaverick72
    fordmaverick72 Member
    Milwaukee, wisconsin
    1972 ford maverick 302 30over aod with 8.8
    had same prolblem for 2 months. did plugs,rotor,distributor & cap,plug cables,wiring harness.and still ran rough getin worse with time. had to keep timing really high or keep foot on gas. starting to burn really rich. then yesterday.got off freeway and yup. timing chain and cam wer worn down.timing chain loosened up to point where it would flood out at idle and blow flames out the carb. if you did all the other timing stuff check timing chain or gear like he recomended.
