floor shifter
Discussion in 'Technical' started by jmontg01, Mar 7, 2010.
  1. 71gold
    the way the stock lever works I don't see that working...:hmmm:
  2. justin has a 74
    kentucky
    put the rod end through the hole, right?:huh:
    EDIT: or flip it so you can adjust it attached with a bolt
  3. 71gold
    there is no rod end...all the shifting stuff is inside the transmission.
  4. jmontg01
    jmontg01 Member
    Arlington, Texas
    73 Maverick 2dr
    its a column shift the neutral safety switch is on the column I think
  5. 71gold
    that's why you need..."the early floor shift neutral safety switch."
    ...:yup:...
  6. PaulS
    The early floor shifter neutral safety switch requires a slot in the transmission lever shaft - some of the C4s from the 70s don't have the necessary groove cut in the lever. If that is the case then the transmission mounted switch won't work. You can mount a switch on most shifters or make a bracket to mount one on your shifter.
  7. 71gold
    ...and if that isn't the case, it will work fine like mine did...:yup:
  8. justin has a 74
    kentucky
    it goes on the ouside and slips over the shifter arm (attached to trans to change gears):yup:
  9. 71gold
    on a manual transmission...on a C4 there is no shifter arm...:disagree:
  10. justin has a 74
    kentucky
    then whats it called? its the arm that changes gears P R N D
  11. PaulS
    Justin,
    It is a shifter arm but it is called a manual lever or selector lever.
    It all serves the same purpose. In england they call a car a "Motor" and they don't go for a drive, they go motoring. Language can be very limiting and confusing.
  12. 71gold
    mount the n/s switch then mount your bracket [​IMG]
    and take a pic.
    ...:yup:...
  13. justin has a 74
    kentucky
    your just being picky, i dont think he plans on putting the switch on the trans right away. You can get it real close to the stock one so there might not be a problem:hmmm:
  14. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    WELL,,, just gotta say it,,,, between my shoulder and my hand that is on the shifter of my C-4,,,,, THAT would be called a,,,, shifter arm ,,,,,
