Front & Rear sway bars
Discussion in 'General Maverick/Comet' started by Maviboy, Apr 27, 2009.
  1. Bryant
    the caltracs bars wont hurt handeling. they actually help. the alum front bushing used in the leafspring drasticly cuts down on the leafsprings deflection. this gives faster turn in responce.
  2. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    The concern I have with any drag racing device on the rear is that they are made to load the rear tires and this unloads the front on acceleration. They are not intended to aid in turning, but to keep a car going straight. They also can be a problem in hard braking as they are now acting in an oppostite load direction then they are intended. Because of my limited smarts on this, I sent a note to Calvert Racing to ask these questions. http://calvertracing.com/index.php
  3. hotrodbob
    hotrodbob Member
    Here is what the guys at Cal-Tracs say. I stand corrected
    It's optional to run the sway bar. We normally remove the sway bars for weight savings. The Cal-Tracs will improve the cornering ability to where you probably would even notice the bars being gone.
    Travis VanKirk
    Calvert Racing Suspensions
    4530 Runway Dr.
    Lancaster Ca 93536
    661-728-9600
    661-728-9615 fax
  4. Maviboy
    Maviboy ForOnlyRealDrivers
    RICHMOND,CA
    74 Maverick,71 Comet
    Nothin wrong with standing corrected,youre takin the time to gather the info and helping all of us out.:tiphat: Not tryin to build a road race car just want the car to be a little bit tighter on the higher speeds taking the turns on the freeway,im sure when I put my Bullit wheels back on it will help also.Love the look of the steel wheels but the sidewall is just to tall to get any performance on the turns.All my buddys have newer camaros and mustangs so they dont really have too much to worry about. I always get the thumbs up though the only old school in the pack and its a Mavi:thumbs2:
  5. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Would it make any sense to just add a rear sway bar and keep the stock bar up front?
  6. hotrodbob
    hotrodbob Member
    You could encounter to much oversteer with just adding a rear bar. Match front and rear bars will balance the handling.
