Fuel Injection For Straight Sixes?
Discussion in 'Technical' started by soooulpower, Jan 31, 2011.
  1. soooulpower
    Mapleton Depot, Pennsylvania
    Well? What is out there? I know this is a pretty broad question, but I was just wondering. I haven't really been able to find a solid answer about how we'd be able to make any stock 6 cyl Maverick engine EFI. I vaguely remember hearing about mega squirts and throttle body doodads. I know the 300s had fuel injection eventually.
  2. baddad457
    Have you checked out what Ford did with the 300's ?
  3. soooulpower
    It's been tough to find anything specific, but I'm still looking. I just know some of you guys are better googlers (is that a word?) than I am. So far from what I see they used a standard throttle body style. I was looking for more of a direct port deal, but oh well. The 300s are big block anyway right?
  4. simple man
    simple man Member
    Bunnell,Florida
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Have a manifold modified for injectors and get the computer, harness and sensors from a 300 and build your own. My dad's 89 has MPI on his 300.
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
  7. soooulpower
    Hmmm. That sounds like a perfect plan.
  8. soooulpower
    I am interested in those crossflows.
  9. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
  10. injectedmav
    injectedmav Member
    Georgia
    You will have to mill the manifold for 300 stuff. I wouldn't think that it would be worth it. Throttle body injection is an option but if you're dead set on MPI, crossflow aussie head might be best but parts availability would suck! A 2 barrel carb conversion isn't a bad deal either and the 6cyl sites listed above give a lot of info on your options. A header for that engine with a cam upgrade is one of the single best things you can do with it. If you keep the stock head, I would also make sure you get the port separator plate for the center exhaust ports. I personally like the idea of adding a turbo due to the awful intake/head design. (y)
  11. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    I have an Aussie setup and will be using a 4-bbl (Autolite 4100) until I can buy and EFI setup. I like the way the guys at Howell talk. I'm gonna get shot, but GM did make the best TBI setup.
  12. soooulpower
  13. darren
    Wonder why those guys would bother with TBI on a Jeep when you can buy a multi port kit from the 4.0 to fit a 4.2 carb. engine.
    TBI is ancient technology. You'll still have the same crappy fuel distribution you do with the carb. It atomizes better than a carb. but still has distribution issues. Granted it will run better and you wont have to play with carb. settings. If your shooting for better driveability TBI is an option but I wouldnt invest money in it for power.
  14. markso125
    markso125 Member
    Lewiston Ut
  15. baddad457
    After having driven an injected 4.0 Jeep, I don't see why anyone would want one. No balls and 9 MPG. This was an 04 model, I had a carbed 258 79 CJ-7 and it would run rings around the 4.0 and get a couple MPG better.
