Fuel pipe modification question
Discussion in 'Technical' started by HarleyGA, Sep 28, 2018.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    My Maverick fuel pipe was engineered for leaded gas. It’s frustrating trying to fill my gas tank without the fuel splashing out. Does anyone have a solution for this problem?
  2. rthomas771
    Swap filler neck with a late model neck. Comet and Maverick necks uses different bolt pattern. I have no splash-back problem with later filler neck on my '74
  3. Krazy Comet
    You can swap fillers as mentioned, but problem with splash back was there when car left factory. The leaded nozzles were only slightly larger than the unleaded.
    Crazy Larry likes this.
  4. 71gold
    see you in the morning...Frank and Effie
  5. 71gold
    hope to see you also...Frank and Effie
  6. William623
    Orlando
    1973 ford maverick grabber
    I did the same. No splash back at all with the later neck.
  7. Craig Selvey
    I have a 1976 with the exact same problem. :(
  8. baddad457
    :idea: Splash back ? Hold and control the nozzle. :slap: :stirthepot::thumbs2:
    Hotrock and Krazy Comet like this.
  9. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    This is what I do now!! Poor solution when you have a bad lower back. I guess I need to find a late model fuel pipe.
    baddad457 likes this.
  10. baddad457
    I'd give you mine, if I knew what I did with it. I put a Nascar fuel cell in the trunk of my 77.
  11. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Close but no cigar! Thanks anyway.
  12. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I have a 75 with the neck for unleaded and a 72 for regular. Neither one, as is, is ideal. However I found the 75 more problematic than the larger 72 neck.
