Fuel tank setup diagram
Discussion in 'Technical' started by DocRoche, Nov 4, 2015.
  1. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Seem to have a gas leak coming from the tank on my 73. Going to take it apart this weekend and put new filler hose and seal on it. But I can't seem to find a diagram anywhere that shows me the parts I need or how it goes together. Probably not very hard, but I'll have to order the parts so I was curious if anyone had this.
  2. Craig Selvey
    I doubt that the filler neck gasket is leaking. Tank has to be completely full to leak there....and would only leak down past the gasket....which would be very little.
  3. rthomas771
  4. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Thanks. I know when I filled it the other day the automatic shutoff on the pump didn't work and overfilled the tank. So when I went to fill it again I made sure not to overfill and stopped it myself. My wife was behind me and said when I pulled away a onto the road good amount of gas seemed to pour out from the back of the vehicle. I don't really know what would cause that. I did fill the tank but I made sure not to overfill.
  5. Dave B
    Maybe it's the seal on the gascap?
  6. DocRoche
    DocRoche Member
    1973 Ford Maverick
    That's a good possibility. I had not considered that.
  7. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Where would you find a seal/gasket for that. My local parts store doesn't seem to have it.
  8. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Wife said it looked like the leak was coming underneath the vehicle around the middle of the tank. I'll need to give it a better inspection.
  9. Krazy Comet
    If it is the tank doughnut, it's going to cause a leak on acceleration as the gas sloshes to the rear of the tank.... Probably leak at half tank or less...
    Craig Selvey likes this.
  10. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Would a later model filler neck fix this? A lot of people seem to be replacing this with a later model.
  11. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Suffice to say .. Don't park this car in an " enclosed" garage till you FIND the leak and deal with it.. Nuff said !
    Cometized
    (Chip)
  12. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Yeah, sitting outside. Hope to figure it out this weekend. Doesn't seem to drip when parked. Just during acceleration.
  13. Craig Selvey
    Just get a new filler neck seal/grommet. All the aftermarket companies have it, and they are also on eBay.
  14. DocRoche
    DocRoche Member
    1973 Ford Maverick
    OK. I did first consider it. But my wife said when I pulled out of the station a large amount of gas poured out right after I filled up. I figured it might be the neck
  15. Mavman72
    If its the filler neck. They do get rusty right at the grommet on rot box cars. Still...It sounds like its getting past the grommet at the tank that seals the filler neck. Pull 5 sheet metal screws on the filler neck flange (Right on tail panel behind gas cap) Twist/pull repeat(Careful...Theres a cork gasket between the body/flange too) and it will slide out of the tank/car. Pull 4 sheet metal screws on rubber cover in trunk that filler neck passes through. Now you have access to the grommet on the tank...Simple to do and you dont have to drop the tank...Good luck!!!
    71gold likes this.
