yep.. I like it too. Now that I see more pic's.. those angles coming off the sides don't look quite so severe now. I'm curious about the end tabs and thier bolts though.. won't that seperate the mating surfaces between the valance and fenders? Or is it just mocked up with the bolts for now.. and only the bent over tab will be present between the fender/valance mounting holes when fastened on the car? Seems like they could be tucked under the valance with some careful notching of the valance to let them slide into it. Then the seam will be consistent.
Car started!! Ran great and all the gauges so far look like they worked.... it was a crazy busy day bryant changed my wheels/tires installed the fire suppression system lines in the engine bay got the interior back together got the dash all finished up got the driver seat in, installed washers to make sure I spread the load of the bolts welded up flanges for the exhaust extensions
this thing is awesome, hook up air to it....creates a vacuum, then sucks the coolant into the radiator and makes sure there is no air trapped.... see, vacuum!
