Grabber Scoop attachment?
Discussion in 'Cosmetic' started by Sallythe71, Apr 7, 2018.
  1. Sallythe71
    Sallythe71 Member
    California
    71 2dr
    Hey y’all, I got my 71 into a bit of a fender bender, but found an old beat up 72 Grabber that I can get the parts I need from, and make mine a Grabber clone in the process. Hood has been fixed, primed and sealed, and I’m putting it on the car today, but I’m not sure how to affix the scoops to the hood. Before we took the hood in to get it straightened, the scoops were just siliconed on, are there some kind of clips that were used? The little pins on the bottom aren’t threaded.
  2. 71gold
    they were held on with some weird little nuts...:yup:
  3. 72MAVGRABHER
    Roanoke, Va.
    The scoops themselves had 3 studs I think that went thru the holes then you have 3 metal self cutting type nuts if I remember correctly. It’s been awhile since I looked at mine. I can take a picture in the morning if no one else gets to it first
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    71gold likes this.
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    You can find those weird little nuts at at good electrical supply store. Take the scoop with you and try them at the counter . I did that for my 71 Grabber . Same problem. I don't know the ' technical ' name for them .. but I KNOW they had them when I visited the store. Hope this helps.
    Cometized
    (Chip)
    71gold likes this.
  6. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Speed nut.?
  7. Craig Selvey
    Yes....speed nut.
    AMK Products has them...as well as Melvins.
  8. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    AMK has discontinued the correct palnut. An alternate solution is being looked into.
  9. Miguel Arzola
    Long Beach Ca.
    Any car dealer they have speed nuts take you old one so they can match the size my not be a barrel nut but regular flat speed nut
