granada 351w exhaust manifolds in a maverick
Discussion in 'Technical' started by maverick7072, Jun 22, 2021.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i ran across a guy who has a driver side exhaust manifold from a granda 351w and it is shaped a lot like the factory maverick 302 manifold but the exit and ports looks like ei might breath better ,just curious to know if anyone has ever tried granada 351w manifolds in a maverick
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If you really want it to breathe better ditch the factory cast manifolds altogether. It will bolt on of course but any gain will be imperceptable.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    yes i was afraid someone was gonna tell me the ditch the manifolds but all I wanted this thread to be was to find out if the 351w granada manifold would fit in out cars,if I can get my hands on this manifold someone might need or want it,not everyone wants headers
    jasonwthompson likes this.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    I'm pretty sure that Maverick exhaust manifolds are specific to Mavericks/Comets. The Granada manifolds will certainly fit the engine, but I believe the angle for the down-pipes is wrong for the Maverick. It would definitely be a gamble as to whether or not you can make them work...
  5. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    the angle on the outlet comes out just the same as the maverick manifold only difference I see is that the manifold is thicker and the runners seem a bit wider
  6. TeeEl
    TeeEl Senior Member
    Colorado
    I guess if it clears the steering box and everything, it would work. What about the passenger side?...
  7. Krazy Comet
    AFAIK most if not all the driver side 351 manifolds are shaped similar to the Maverick/Comet 302. Fairlane, Torino, Falcon ect 289/302 driver manifold exit is above shift linkage, 351 below.
    Eons ago I swapped a '69 Torino FMX trans into a 289 '67 Falcon, found trans linkage & exhaust would not play nice. Wound up swapping Torino 351, FMX, exhaust pipe, column & all the linkage into Falcon. As a complete unit was a direct swap.
    All this said, I dunno if any 351 manifolds can be used in Mav/Comet.
    TeeEl likes this.
  8. mojo
    Only way to know for sure -- If you have the manifold "Try it, and end the suspense!
    Shorty and BBMS18 like this.
  9. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i will say i have never seen another driver side manifold like this one before but like I said it came off of a 75 granada that had a 351w the outlet on this one is exiting the exact way the mav manifold does its just a little thicker manifold. i have a driver side 351w that came off of a torino and it exits below like you said. i think I will get it even if I make wall art out of it
  10. TeeEl
    TeeEl Senior Member
    Colorado
    Well it "sounds" like it will work, but what is the point of having mis-matched exhaust manifolds? According to your description, the driver-side would be more free-flowing than the passenger side. Maybe I've missed something (wouldn't be the first time)...
    mojo likes this.
  11. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i didnt say i was gonna use it .i said i may use it for wall art
