hello need some help
Discussion in 'New Members Forum' started by anthonyv90, Jun 7, 2008.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    my 1970 maverick is leaking power steer fluid.what should i do?
  2. blugene
    Rebuild your motor and transmission. :rofl2:
  3. blugene
    Just kidding! :)
    You probobly want to check to see where it's leaking from. Could be a hose, pump seal or other related part. If it's bad enough you can see it. Sometimes if you clean it that helps too. At times you can get someone to turn the steering wheel as you look around the wet areas and see if it squirts. You gotta have fluid to see if it squirts tho... oh, and :Welcome:.
  4. anthonyv90
    anthonyv90 Member
    okay thanx i'll try it.
