Help with rewiring the car...
Discussion in 'Technical' started by mashori, Aug 18, 2012.
  1. mojo
    I have that same fuse panel for my switched aux accessories mounted under my package shelf. I use it for my gauges '"volt meter", choke, radio and elec fan relay trigger. I mounted a binding post on the heater box so I don't have to cut the thick wire if/when I want to service something, for whatever reason.. I do have it on a 40amp fuse and relay, at present am using only 3 fuses.
    It has work well for me so far. I don't have to worry abt tampering w/ the O/E box.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Did the installation today, came out very clean and nice. So I have this one which is my 12V switched ignition accessory panel and I have a constant 12V one as well that I installed. Used a relay and fuse for the 12V switched auxiliary panel.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    found a new location on the firewall to relocate the solenoid...much easier to access....
    Bryant got me the harness for the speed sensor to attach to my electronic speedometer...
    there was more shoddy wiring done for the A/F gauge, cleaned that up too...
    I ran wires to all the gauges....the ignition wires will all go together, the grounds and the lighting wires will all go together and attach to a Deutsch connector.
    we laid them all out and started cutting the wires to length....
    I started by grouping the reds together, those are the ignition wires
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this was quite tedious work, not hard but not being able to do it fast made it somewhat frustrating....
    I started zip tying everything together to make a somewhat neat harness of wires....
    I ended up with 17 wire ends...
    The connectors have numbers on them so it's nice being able to correlate each wire with the correct number so when I go to mirror the same thing on the car it will be that much easier...
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    and it's done!!
  6. John Holden
    John Holden Member
    NJ
    I like the connectors. Where do you find those?
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Now I have to tackle this mess....
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    they are called Deutsch connectors, they are made by various companies, different sizes and colors.
  9. Bryant
    the dash harness looks really good.
    but why dont you just get a c5 corvette.
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Ew....Corvettes!
    But thanks for all the help with the harness, came out way better than I thought.
  11. Dave B
    That would just make the Smart Car sad :(
  12. Bryant
    has a smart car ever ran in the silver state classic?
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    no but I may need to use the smart if I don't get everything done in time....
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    doesn't look so neat in these pics but cleaned it up a lot under the dash....
    I have all the fuses and relays temporarily mounted in this location until I can figure out the best way to mount them...
    this area still needs cleanup but should be ok once I finish up the fire system...
    changed out the speed sensor to electric one, bryant tested it and it works...
  15. Dave B
    Just get it done!! I wish I was closer, I'd be helping anyway I could. I think it's awesome, and an awesome race to have a Maverick doing.
