Help
Discussion in 'General Maverick/Comet' started by anthonyv90, Mar 19, 2010.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    I have a 71 maverick 200ci and 2 days ago my car started making a squeking noise when I would try to turn to the right. When I turn it to the right it feels like if my car has no power steering..it's really hard to turn it to the right plus it makes a loud squeaking noise but when I turn it to the left it turns smooth w/o any noise. What's wrong with it I need help:huh:
  2. Earl Branham
    Lugoff, SC
    Sounds like a loose power steering belt, or a bad pump. Try the belt first, and if it looks good, be sure it is properly adjusted...1/2" of play. Good luck!
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Check your wheel bearings.
  4. CaptainComet
    The power steering system in our cars is an odd arrangement... it has a ram that drives it both ways. The valve that switches it is at the end of the center link.
    If it works well one way, and not the other, I suspect a problem with either the valve (most likely) or the ram itself. First check for an obvious problem with the hoses between the two, or leaking when turning in the direction that is giving you problems.
