lol so my best bet is to buy the lokar kickdown cable and throttle cable? if so could you give the links for the throttle cable i need and if i need anything else with it and thank you very much for the help you don't know how much a little guiding is a big help
The inline 6 cable will not work. I'm not sure what you mean by buying a throttle off of lokar. Are you referring to the throttle shaft? That is a Holley part if so. My picture shows two cables, one is a throttle cable and the lower one is the kisk down. They both are attached to a bracket I bought at the same time. I got the stuff from the place in the link I posted. I bet the other parts (throttle cable and bracket) are in the link. I'll look cause i'm curious.
i was talking abou buying this http://www.summitracing.com/parts/LOK-SRK-4000/SuggestedParts/?prefilter=1 this http://www.summitracing.com/parts/LOK-KD-20C4HT/ and this http://www.summitracing.com/parts/LOK-TC1000U36/
The throttle cable and bracket are on page 90 http://www.sachserodshop.com/web_driveline.pdf at the top. Here is the link to the actual site. http://www.sachserodshop.com/
Looks good. The 36" cable is a bit much I think. I want to say I got the 24". Not sure how the prices compare especialy after shipping also.
these are the ss brackets Dual S.S. Return Springs Only (Pair).... LKR SRK-4002....... $13.95 and Bracket W/S.S. Dual Return Springs..... LKR SRK-4000....... $25.95 this one i think i need is this Bracket Only.......................................... LKR SRK-4001....... $13.95 so overall and after i buy those parts i would be good on everything? like as in brackets and stuff for kickdown and throttle
Those return springs are needed... unless you have some others. I would stick with the package deal so your not scrounging for springs later. These are also designed for the application.
I am betting that you will need a new throttle shaft for the carb. I would find one that has the stud if you need one. You have the hole for the stud, but you will also need a slide stud (not exactly sure what it is called) at the bottom for the kick down cable end the slip onto. I can't tell from your pics if there is a place for it AND I don't remember if that was something I had to get. I will look at it tomorrow and see if I can remember. Here is a tip also. You should avoid setting the carbs down with the weight laying on the linkage. Set it on a 2x6 or something where the linkage is not touching the table top.
In the real world I am guessing a "High tech throttle cable" is one that someone thinks requires an education to understand how they work lol. A universal black one works on several applications, not necessarly different manufactures.. In my opinion, to use the term "high tech throttle cable".. that sounds like sarcastic language.
