Hood Won't Open
Discussion in 'Technical' started by soooulpower, Apr 4, 2015.
  1. soooulpower
    Mapleton Depot, Pennsylvania
    I'm getting back into working on the Maverick again and I ran into a huge snag. I've had the Maverick sitting for awhile after the radiator blew and I was checking to see if there were any other problems I'd need to take care of immediately and I ran into a big one. When I went to pop the hood to check the engine the hood just would not open. The release handle does move up towards the hood, but that sucker is jammed. Bad. I really can't think of anything to do other than shoot the mechanism with WD-40 and pray. Any ideas?
  2. Krazy Comet
    I opened one on a '73 just a couple weeks ago that had been setting well over a year, used PB Blaster... Had to work it several times but it finally released...
  3. soooulpower
    I prefer to use PB Blaster and I happen to have a can. I've been moving a bunch of furniture lately and didn't have a chance to give it a try, but I definitely will now. Thanks!
  4. Craig Selvey
    You can also remove the bolts on the hood latch....or on the center grill support...and get it open.
    SlotlessMan, rthomas771 and 71gold like this.
  5. soooulpower
    Ah! Hadn't thought that far ahead. Excellent backup plan. Thanks, Craig.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Im pretty sure you have but pull the hood latch open and hit the hood right above the latch
  7. soooulpower
    I used to be able to push down on the hood and then try to open it again and it would work, but not anymore.
  8. soooulpower
    PB Blaster did the job. Thanks again, guys.
