Identify a rear end
Discussion in 'Technical' started by Dean Deeter, Mar 27, 2006.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you just put your 8" tubes on the 9" center, you don't need to cut any axles or remount the spring pads!
    This is what Ford and Shelby did in the sixties before they got around to engineering a 9" rear specifically for the Mustang.
    Around here, competent shops get 150-200 bux to put your tubes on a 9" center.
    You just need to make sure the chunk has 28 splines, rather than 31.
    This way you keep your brakes, spring perches, axles, bearings, etc...
    The only thing the shop has to worry with is keeping your pinion angle and mounting the tubes square. They use the same bar jig as if narrowing the rear, but without all the extra hassle.
    Dave
  2. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Yup. I did just that. Had a 9" out of a luxobarge narrowed used my 8" 28 spline axles. Easy and worth it. Now runs 3.70s with a detroit locker in the 9"
  3. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Hey 69gt, If you don't mind , What did it cost you to have it cut down. Dean
  4. 69GT
    69GT Member
    Fresno
    I dont remember exactly how much but it was not much or I would have remembered. It was less than $150. Just used my same 28 spline axles out of the 8" Fits dead on perfect. Looks like it came that way. Used my 8" to get all the measurements.
