Input on switch from 2bbl to 4bbl on 76 Mav?
Discussion in 'Parts Interchange' started by mrbusto71, Jul 22, 2016.
  1. mrbusto71
    mrbusto71 Member
    Minneapolis
    76 Maverick
    Hi there! New to the forum, I searched around and I hope I'm posting this in the right spot.
    I'm new to the world of working on cars (something I've wanted to do for ages!), so I'm not really familiar with everything yet. That said, I bought a 76 Maverick as my first ever project car, and after doing research online I'm still kind of confused as to whether or not it'd be worth it to put a 4 barrel carb/intake on the 302 v8 engine?
    Gas mileage isn't a concern of mine, this car is there for me to have fun in and learn how to work on, so anything that'll give the car a performance boost is what I'm after.
    I'd love input/advice! My only request would be to explain things to me like I'm 5 though, as I'm still learning terminology and stuff.
    Thanks!
  2. 71gold
    :Welcome:...:Handshake:
    "this car is there for me to have fun in and learn how to work on."
    I would suggest driving the car a little to get the feel of it, check out any issues it may have.
    then decide on where you would like to go with your build.
    Frank
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I highly recommend a 4-barrel swap. I also agree with Frank's suggestion.
  4. Hotrock
    Munroe Falls, Ohio
    Welcome to the site from northeast Ohio!!! :tiphat:
    I also agree with Frank and Crazy Larry.
    I suggest buying new components as opposed to something from a swap meet etc. At your level of automotive knowledge, you do not need the extra difficulties that may come with used parts especially carburetion. I suggest the following three items plus gaskets.
    https://www.summitracing.com/parts/wnd-8020wnd/overview/make/ford
    https://www.summitracing.com/parts/sum-m08600vs/overview/
    https://www.summitracing.com/parts/sum-g3001/overview/
    Have fun!!!
    mojo likes this.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I think Hotrock nailed it. That is exactly what I would have recommended. I think the Weiand Stealth is one of the best intakes for the small block daily driver. Everyone has to start somewhere.
    Hotrock likes this.
  6. mrbusto71
    mrbusto71 Member
    Minneapolis
    76 Maverick
    Woo! You guys are awesome! Thanks so much for the feedback!
    Yup, I've driven her around a bit and she's pretty healthy for being as old as she is. Definitely has more 'oomph' than I'm used to (I've driven 4 cylinder commuter cars or giant Cadillacs almost exclusively).
    I've been trying to do my due diligence and read up about the benefits of performing the swap, but the only thing I've taken away from that research for sure is that I should stay away from a 2bbl to 4bbl adapter, whatever that is. So my main question is, if I swap out the intake manifold, carb, and air filter, where will the benefit be most noticeable? Standard acceleration? Higher top-end speed?
    Sorry if this is a dumb question, but since y'all were nice enough to answer, figured it can't hurt to follow up with the silly stuff if it helps me learn.
    Thanks again!
  7. Hotrock
    Munroe Falls, Ohio
    Yes!!!!
    71gold likes this.
  8. mojo
    No question is a dumb question! That's what the forum is for -- help fellow enthusiast/owners solve their problems.
    No one knows everything -- but there is enough knowledge here to eventually figure most anything out.
    Welcome to the forum! :Handshake:
  9. 71gold
    if you decide to go 4 bbl...may want to bump the cam up with new lifters to take advantage of the extra fuel/air...you'll be half way there when you pull the intake... :chirp:
  10. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    And here we go...
    Hotrock likes this.
  11. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    4 barrel swap was the best thing I ever did to my car. Took a bit of tuning to get the carb setup right. The parts posted previously is close to what I am running now. You will get even more benefit if you open up the exhaust a bit. Mine still had the stock system and made jump in improvement when I switched to duals.
  12. 71gold
    the...Domino Affect...:bouncy:
    carb=intake=cam=bigger heads=bigger exhaust=3:55 rear gear=radiator=transmission rebuild=bottom end rebuild=etc=etc.
    Maverick Dude and jasonwthompson like this.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I think it's both an Effect and an Affect.
    And $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ :49:
    71gold likes this.
