installing a electric fan to a toggle switch
Discussion in 'Technical' started by lynhrt210, Mar 13, 2010.
  1. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    If street driven, I would hook up sending unit to turn on auto. Someone WILL forget to turn on! Rocker an relay should be fused! or rocker can switch/ground of relay
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I used to have my fan on a toggle, worked good till I forgot to turn it on when I needed to (letting the car warm up while I was talking to friends in a parking lot, conversation went on longer than expected) and ended up spewing antifreeze all over the ground. sents then I've installed a temp switch, much better. just my 2 cents. btw the temp switch was about $10 to $15 from autozone or checker.
