000pppssss sorry for the mix up !!!!! the push rod checker, I use for checking the rocker travel on the valve tip and for correct push rod lenght.
I got my adjustable pushrod from Comp Cams. Nice piece as each complete revolution equals .050" for simple length calculation. http://www.compperformancegroupstor...=CC&Product_Code=CPSHRD&Category_Code=PSHRDTL
I am looking for screwin stud for my 302-87-roller moter e-7 heads 5/16-3/8 can't fing or procedure for using an ajustable pushrod checker!!!!!!!!any help thanksAlex Kustomguy123
Where can I get screwin studs 5/16-3/8 (suposedly comp cams used to make them but nolonger) or procedure for adjustable pushrod with heads and intake on engine '87 -302-w/ e-7 heads Thanks Alex
Hey new guy, try to shoot Mavman72 a private message. Then when he logs on next time, he will automatically see the question. I doubt he would ever visit this thread again, and he would never know you are looking for them.... By the way, welcome to the forum, and hope you find what you need
http://www.summitracing.com/parts/CRN-99146-16/ Try this out. Word of warning though...The pedestal heads dont have alot of material on em for machining em to use 3/8" studs (can be done but iffy with high spring pressures) so this is the next best thing. Good luck!!! Scott...I look at the old stuff from time to time...
