Lookin for a 302
Discussion in 'Technical' started by Tomhopson, Nov 17, 2010.
  1. don graham
    Remember if you go any faster then you also need to be able to stop faster. These cars weren't designed for speed. :)
  2. maverick75
    Gear swap will make a great improvement. With that 300 you can get a gear swap. And it will work great when you go over to a V8. If you plan on using a C4 then go with 3.55 gears. It will make the car quicker.
  3. maverick75
    X2. If you still have four way drums then you should really swap to disc`s up front.
  4. Tomhopson
    Tomhopson Member
    Jacksonville Florida
    I'm gonna switch the breaks pretty soon it what else can I do to the engine to make it faster
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    An intake, header and a cam would wake it right up but won't be cheap. My suggestion is to take the money and save up. You can blow a ton of money chasing your tail only to throw it away when you decide to do it right. Trust me, this is experience talking here!:beerchug:
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    get a 8'' or 9'' rear end with some 3.55 gears for the best results
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    X2- thats the best place to start, then brakes, then motor!
  8. maverick75
    You cant swap the intake on the 6s :D . I wouldnt really do anything to the engine, since he`s planning to do a swap...... Like you mentioned saving up is better. Also V8 parts are cheaper than the inline stuff.
  9. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    Keep the 200 in there,and enjoy it for what it is.Inthe meantime start doing upgrades to the rest of the car,front disc,a better 5 lug rear axle,save up for v8 springs,mounts,etc.No use pissing away $ on an engine,that your going to pull anyways.Me,I'd start with the v8 disc,then add a rear 5 lug axle,and go from there.On a very limited budget,you gotta spend the $ where it's gonna count the most.
  10. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    First thing you need to do is get a job and save your money so you can actually afford to fix this car up right. If you go dirt cheap on stuff it generally bites you in the butt later.
  11. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    i have a 93 5.0 ho short block its bored 40 over so its a 308 i want to sell it for proly around 200 bucks but ill take 150 for it
  12. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    Before I swapped in my 306 I did a 2v carb conversion and it gave a lot better throttle response, idk about top speed but it had a lot better get up and go, if you know what i mean. Cheapest power adder you can do, cost me 13 bucks for the carb adapter and I already had one of the carbs lying around. but you could pick one up for about 50 bucks. Check out the 2v car swap in the tech articles.
  13. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    I agree with earlier advise ... if you are eventually going to the V8 don't spend a dime on that 6-banger. Front disks and 5 lug rear first(y)
    General advise is to plan out your final build and start searching and looking out for "deals" for the things you need to make it happen.
