Lowering the maverick . . .
Discussion in 'General Maverick/Comet' started by mashori, Jun 11, 2011.
  1. Bryant
    dam those are sexy!
  2. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    From an engineering perspective, this kit provides several advantages over the Total Control kit.
    http://autofabcart.net/1967-1970mustangtubularcontrolarmsandcoil-overconversionkit.aspx
    The Total Control kit uses the same spring mount location as the stock spring. The Autofab kit mounts the lower end of the coilover just inboard of the spindle on the lower control arm. This give the advantage of better leverage which means lighter front springs and a better motion ratio. The lighter front springs will give you a quicker response to bumps and better ability for the tire to stay in contact with the pavement.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  4. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    Mine is 24 1/2" in the front and 26" rear.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I see your point about leverage since the mount on the LCA is further away from the point of rotation of the LCA but since the spindle is solid and attaches the LCA to the UCA I don't see the leverage making any difference.
    The shock travel isn't changing much either it appears since the upper part of the shock is now a new solid piece that sits much lower than the shock tower. That's how I understand it.
  6. jayman
    jayman Member
    San Diego, Ca
    It is a matter of leverage. The spring acts on the control arm closer to the wheel, therefore it requires less effort to move the control arm than if the spring was mounted half way down the arm. This allows you to run lighter springs which will respond faster, have less weight and give a smoother, more compliant ride.
