manual disc-brakes
Discussion in 'Technical' started by 70mav01, Feb 25, 2007.
  1. 70mav01
    70mav01 Member
    desoto, Mo
    1970 maverick
    Does anyone have the manual disc-brakes? I found a Granada with them in a junkyard yesterday, minus the rotors. I really don't want the huge booster under my hood, so thats why I haven't gone with the power disc's yet. My car has manual drums now. any suggestions?
  2. stmanser
    Davenport, Iowa
    yes.. the manual disc brakes work great on our cars.. it will give you all sorts of stopping power..
    just get the proportioning valve and the dist block along with all the brake hardware
    you can also do a search in the forum for a how to do it i believe
  3. Mavaholic
    Manual disc are much better than drums, however I never noticed a whole lot of difference in the amount of pedal pressure it takes to stop the car. The power assist is what gives you the easiest feel. I would definitely convert to the disc, just dont be surprised if it really dont feel any different effort wise.
  4. 1slow7t
    1slow7t Member
    Puerto Rico
    70 Maverick, 6 cyl/auto trans, soon to become a 351W w/pan fed C4.
    Sorry to interrupt, does the Granada booster fit in my 70 Maverick?
    >About your case, I'm with the above post, you might not feel a significant improvement with manual discs. IMO, there's a master cylinder bore & caliper piston diameter &/or volume combination, to make a manual brake set up work at its best.
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I have manual disc brakes, and yes, they do perform significantly better than drum...
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i also have manual disc brakes. stops much better.
  7. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    The biggest caliper piston and smallest master piston is the best combo.
    You'll have a lot of pedal travel on that though.
