Manual Steering vs. Power Steering
Discussion in 'Technical' started by Positively Ralf, Oct 9, 2009.
  1. Jeff S
    Jeff S Member
    NoVA
    none
    Exactly what is involved in removing P/S? Is there a tech article on it or does someone care to share? I havent thought about it until I just saw this post. My P/S doesnt leak but its crazy going around curves in that thing, feels like it always want to oversteer
  2. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    yo need the front end parts out from under the car with manual steering. tie rods and drag link.
  3. Mavman72
    You will need... Pitman arm...Center link...From a manual steer car.Get a new idler arm while your at it too...
  4. Jeff S
    Jeff S Member
    NoVA
    none
    Thanks, sounds pretty simple to do :thumbs2:
  5. baddad457
    You don't need to change the tie rods unless they've got slack in the joints. Just the centerlink and pitman arm is all. The suggestion about the idler arm is a good one. When you take it all loose, that's a good time to remove the slack (if any) in the steering gearbox.
  6. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    I have a leak getting ready to put new tie rods in and upper ball joints lower still in good shape. thinking about converting to manual. what is involved and what does it cost. I have junk yard connections! with 2 mavs and two granada's. should i go with new parts. there is leaks in different places? maybe th fan blowing everything around. it has been on jack stands all winter! restoring it for my son! fresh interior now we are moving to the bottom! Pretty good leak!! i suspect several places!:( can rebuild control valve. Dad works in tool shop!!!!!!
  7. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    there is no advantage...manual steering is simply better than power...in our cars atleast...that is unless u get a msII front suspension...than i'd go with a power rack. (rack and pinion steering has much less play than parallelogram steering especially with a power assist)
  8. scooper77515
    The ford power-assist system sucks. Period. Too much play before the power valve kicks in and does it's job.
    I would either go full manual (as I have done, with nice and tight steering, no slop, no swim, etc. ) or switch to a power system that is aftermarket that works out all the slop, which I would assume the aftermarket MII kits would do.
    Yes, power is nice, if you don't mind swimming back and forth 4 inches each way with the steering wheel to keep the car on the road in a straight line...
  9. random hero
    hudson valley
    1972 maverick
    kinda like they drive in cartoons...lmao:drive:
  10. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I have a question. I have not even started restoring my 72 Maverick yet but it does have power steering on it. I would think if properly rebuilt or replaced it should not leak but what do I know? lol
    My question: Is there anybody on here that remembers driving a NEW Maverick or Comet with power-steering? Did it steer too easy like said here and did it leak?
    clint
  11. 55crownvic
    55crownvic Member
    colorado springs
    If it isnt leaking....u need to check if it has fluid!!!:rofl:
