Mav update!!
Discussion in 'General Maverick/Comet' started by jpollard, Feb 16, 2004.
  1. LoxMan71
    LoxMan71 Rice Its whats for dinner
    Kansas City
    1971 Grabber and my DD a 2001 Focus ZX3
    So do you just clean the area and then spray on the bullet? Also its sold in quarts so does this mean it can be sprayed in an HVLP gun? The pics look great, and provide much inspiration for my next project, which is lining the trunk and the stripped floor....Later
    brett
  2. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Yep...I imagine the cleaner the better and remove what rust you can. I sprayed mine out of a detail gun and brushed it on in other places, it leaves a nice finish. Put on enough to make sure it can soak into the rust. Good luck with the project....keep us informed with more pics, it looks like you have been busy.
  3. LoxMan71
    Kansas City
    So does the paint require a reducer to flow through the gun ok? I only have a 1.6 tip and that slick sand stuff we sprayed yesterday had a really tought time going through a 2.0 tip...thanks for the info J...
    Brett
  4. jpollard
    jpollard Member
    Montana
    Nope, no reducer. Dont mix it with anything, it is meant to be sprayed on as is.
  5. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    jpollard, looks great! (y)
    I hope to see it in person, and check it out! :cool:
  6. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    jpollard, how much Rust Bullet did you end up using, and how is it holding up on your test piece? Also did you have to rough it up before putting the Rhino liner overtop? The stuff's not cheap up here at $155 CDN a gallon, but if it works it'd be worth it.
  7. jpollard
    jpollard Member
    Montana
    I used about a gallon for everything with next to nothing left over. I also did my gas tank, bell housing, steering box, and master cylinder. So far it is holding up well. No, I didnt scuff the rust bullet before I sprayed on the liner. It seems to stick pretty good. No, its not cheap! Spray it on if you can, it seems to go farther. Good luck....
    JP
  8. MapleMav
    MapleMav Member
    '72 Sprint
    Thanks jp!
  9. runum
    runum Member
    maverick
    All I can say is WOW!:clap:
  10. Rust Bullet
    Rust Bullet New Member
    Dallas, Texas
    1967 Camaro SS/RS 396
    jpollard
    Hows your Rust Bullet testing holding up ?
    Dave
  11. hotrodtemptress
    hotrodtemptress Member
    ohio
    1970 maverick
    wow that is totally great. !!!!!!!!!!:clap:
  12. MikeG747
    MikeG747 Member
    Arkansas
    J Pollard how is the Rust Bullet holding up for you since this post was 3 years ago?:huh: Please give us an update.(y)
  13. jpollard
    jpollard Member
    Montana
    Rust Bullet update
    Hi guys, I cant believe it has been 3 years since I updated this post. Time flies. I haven't been on here much in the last 2 years, it has been a pretty hectic time but I often think of everyone on here and check it out every month or so. I couldn't have built my Mav without the members on this board.
    Ok..on to the Rust Bullet. So far this stuff has held up great!! I put a patch of it on my differential without any prep of any kind, just straight over the rust. It looks today like the day I put it on, I am impressed. Most of the rest of the Rust Bullet is under paint or rhino lining so I cant tell exactly what is going on there but I see no problems. The paint and lining have held on to it and no rust bubbles are visible anywhere. I would have to recommend Rust Bullet but you have to remember my car is garage kept most of the time and only sees bad weather once in a while.
    I attached a pic from last summer. I will get more taken and posted this summer. I am going to try and get it on the Mav calendar if there is one this coming year.
    I have moved to Montana since I finished the Mav. If anyone is ever up this way, please let me know and stop by. Hopefully you will be seeing a lot more of the Mav but I will keep that under my hat for now.
    Thanks again to this board and everyone on it.....
  14. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for the update! That is a great testimony with 3 years experience on this stuff. That's the kind of info we need. Great looking car.(y)
  15. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have seen the car in person,,, it is gorgeous!!!!!
    Dan
