Maverick Problems
Discussion in 'General Maverick/Comet' started by Scraperondubz, Jan 27, 2010.
  1. bmcdaniel
    How about new gas, as in drain out ALL of the old stuff?
  2. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    I drained all the gas out and replaced it with shell premium gas
  3. Moneymaker 1
    Panama City Florida
    Timing is 180 degrees out...check it!
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    What carb does it have?
  5. Scraperondubz
    Oakland, California
    MAVERICK
    I have a carter afb carb
  6. Scraperondubz
    Oakland, California
    MAVERICK
    I PUT A HOLLEY CARB FROM A RUNNING MUSTANG ONTO THE MAVERICK AND IT STILL ISN'T RUNNING CORRECTLY... NO POWER, TIRES DON'T BURN RUBBER AND THERE STILL IS THE ENGINE SHAKE AT IDLE. I AM SERIOUSLY READY TO THROW IN THE TOWEL AND GIVE UP.:cry::cry::mad:
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    did you do anything with egr valve???
  8. Scraperondubz
    Oakland, California
    MAVERICK
    Yes I changed the manifold to a edelbrock with no egr spacer
  9. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    If it ran fine before the intake swap id be checking that alot closer,Did you have it checked for cracks ect? Have you used a vac guage on it?
  10. Scraperondubz
    Oakland, California
    MAVERICK
    Intake was replaced a second time with an edelbrock which I had bead blasted and magna fluxed to check for cracks
  11. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Your gonna have to go back to the basics Spark,Compression,Fuel...Give it a compression check with leak down you may have a valve problem..I wish i was closer to ya id give you a hand..
  12. justin has a 74
    kentucky
    so you do or dont have an egr valve?
  13. Scraperondubz
    Oakland, California
    MAVERICK
    No egr valve or cats or any smog items
  14. douggow
    douggow Member
    Spokane Washigton
    1973 Grabber, Red 71 Grabber, Yellow 71 Grabber
    Burnt valve?
  15. Scraperondubz
    Oakland, California
    MAVERICK
    that's what i am thinking but im doing a compression test tomorrow if it doesn't rain
