Maverick won't shut off.
Discussion in 'Technical' started by Huckleberry, Jan 13, 2014.
  1. Huckleberry
    Huckleberry Member
    Missouri
    72 Maverick
    I am not sure what to take apart to reach the ignition switch. I heard the steering column can be pulled down, yet, I have tried to do so with no success.
  2. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Remove all the plastic trim pieces, then remove the 4 bolts holding the 2 straps that keep the column in place. The column should then just drop down.
  3. Huckleberry
    Huckleberry Member
    Missouri
    72 Maverick
    The pieces feel like they are about to snap at each attempt I take at dismantling them. Is there a layout on taking the pieces off without damaging anything?
  4. 71gold
    what pieces are you referring to?
  5. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Umm they are bolted on.
  6. Huckleberry
    Huckleberry Member
    Missouri
    72 Maverick
    I located 2 bolts at the base of the steering column. There's probably more. I'll won't have time till tomorrow morning to check everything out.
