motor mount
Discussion in 'Technical' started by spookum72, Apr 11, 2007.
  1. spookum72
    spookum72 New Member
    dallas texas
    72 grabber
    do anybody make a soild motor mount for a 72 grabber or can i go with a motor plate and who would i contact for plate :thumbs2:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Hey spook. Are you familiar with the SEARCH button up top? ;)
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I just drill a hole and run a grade 8 bolt through the 2 plates in the mount.
    Ties them together, and if you finish it off with a locking nut, you can adjust how much 'give' the mount has.
  4. don graham
    why do you want a solid mount? i run just the regular stock mounts and have run in the 11's. i haven't had any problems. how much HP you got?:)
  5. Rick Book
    Rick Book Member
    Thailand
    I still want to see a picture of your setup. That idea wouldn't work with mine. :hmmm:
  6. ratio411
    ratio411 Member
    Pensacola
    I'll dig out the mount and snap a pic when I can.
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Solid mounts can break transmissions and cause other problems. The motor has to move...
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    :16suspect
    WAIT....you said can..................................................... nevermind ;)
  9. ratio411
    ratio411 Member
    Pensacola
    No.
    A solid trans mount will break the tranny tailshaft if used with stock engine mounts. The engine will twist, then the tranny will bind, then 'snap' goes the tailshaft because that is where it is binding.
    If the engine had to move, they wouldn't use solid engine mounts or engine plates.
    You can however use solid engine mounts with a stock tranny mount.
  10. Rick Book
    Rick Book Member
    Thailand
    Who/what is your source?
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    S&w has nice engine plates,
    My old Maverick ran 10.30s only had front 1/4 in aluminum plate, no mid plate, and stock rear tranny mount. Never had a problem,, always on my mind though! Also at that time I had a stock c-4 bell housing.
    I know guys at the track with solid mounts all the way around,,no problems and other guys broke trannys till they put flex in tranny mount.
    Always make sure you have good dowel pins in the engine to bell housing! That does create problems with them missing or loose!
    My new car has 1/4" front and mid plate with rubber tranny mount. That's the way I like it. Not saying it has to be that way, just seems the best for me.
  12. T.L.
    T.L. Banned
    Southern Colorado
    A guy with a sweeet 500hp (dyno'd) '68 Chevelle who has broken about 5 transmissions from running solid mounts. When he finally changed to rubber mounts, 'never broke a tranny again.
    I see "Ratio's" point though. The tranny mount was probably the culprit....
  13. Rick Book
    Rick Book Member
    Thailand
    No need to now. I think I have it figured out.
    You're actually drilling a hole through all three plates in the SUPPORT (yes, there are three plates in mine) and one in the MOUNT?
    I would think that the hole in the mount would have to be fairly over-sized (3/6" or so) to prevent any binding in the "axial" direction.
    Am I close?
  14. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    Autoworks International (619-401-6900) makes a motor mount (similar to the Ron Morris Motor mount for Mustangs) that was designed for the Mavericks. This uses a captive bushing, like is used in spring perches, for vibration dampening but is designed so that the motor can be moved fore and aft as well as side to side for aligning the engine in the bay. These cannot come apart allowing the motor to "rock" like a failed rubber mount.
    http://www.mustangsplus.com/catalog/engine_07.pdf
    on page 282.
    I will have a set of these at Knotts Berry Farm if anyone is interested. Autoworks has a list price of $199 for these.
    And, no, I do not work for Autoworks. I do, however, hang out there and have convinced him to make some interesting parts for my car that may be interesting to other people.
