Mr Gasket carb adapter
Discussion in 'Parts Interchange' started by PAINTANK, Dec 26, 2009.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    The carb I used on the Kidnapper Van (318) was 780 CFM. It ran fine. I doubt the secondaries ever did very much, but since it was a vacuum secondary carb I could get away with it. Probably wouldn't have done so well on a mechanical.
    Also, PAINTANK... I just thought of this and figured I'd mention it - be conservative when you're tightening up the bolts on that adapter plate. I had to buy mine twice because I cracked it when I overtightened the bolts. It didn't take much either.
  2. PaulS
    AS long as you are trying to get hp from the engine with an adapter it will work fine - use it.
  3. justin has a 74
    kentucky
    You could always flip it and do a 2 barrel on a 4 intake lol!
  4. baddad457
    :huh::hmmm:
  5. baddad457
    I've got two of these jewels and both were used as such.:biglaugh:They're good for being in a bind, but little else.
