my car is breaking me
Discussion in 'Technical' started by 1974fordmaverik, Dec 11, 2010.
  1. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Just bend it and measure it from the top of the "bucket", I think it should be 7/16" from the top.
    When the engine is running spray some carb cleaner on the sides where the carb makes contact with the intake, if you notice the rpm go a little up, then your carb's base or the intake's surface are not flat. put a sheet of sandpaper over a flat crystal surface and move the carb in "8 shaped" moves until it's totally flat. A micrometer would be highly recommended for accuracy. Having a completely flat carb base helps sealing thus avoiding air entering the engine without passing thru the carb making more demand of fuel when it's not needed.
  2. flynbrd
    flynbrd Member
    Has to be a full leak somewhere, 75 miles to a tank!((about 5 miles a gallon) I find it hard to believe the engine could run to burn that much gas. Your leaking fuel somewhere.
  3. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    i would believe besides the fact that i use to get a little over 200 miles on a tank before i started working on everything
  4. 71gold
    black smoke should be rolling out the tailpipe...:yup:
  5. flynbrd
    flynbrd Member
    If it was running that rich imagine the backfire through the exhaust! I bet the mufflers would explode! or at least give the longest flame thrower I've ever seen :clap:
