Which struts are you using? I understand you can use the Fox body struts with the SN95 spindles if the car is lowered, they are an inch or so shorter from what I've read. That's the ones I plan on using but not sure what brand.
Got the battery box mounted tonight,and the x pipe back on, now to wire it up and change a fuel pump and add fluids
For some reason wiring always takes me longer than I think it will. I think maybe I'm too meticulous.
