one down... one to go... header
Discussion in 'Technical' started by 71gold, Apr 26, 2005.
  1. 71gold
    chris and i got the drivers side header on...hind sight 20 20...now that i know how, it won't take long to do it next time.
    took one bolt out of the motor mount, jacked up motor (a little) and it slid right on...
    jacked the motor untill the fan touched the shroud.. didn't want to take it off again...three times in the last week...frank...:bouncy:
  2. don graham
    glad to hear you got the easy side done.:biglaugh:
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I bet if you actually read the intructions it indicated you MUST raise the engine to install the driver side header! :rolleyes:
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    You da man Frank!
    Dan
  5. 71gold
    dan,
    i did read the instructions...earl told me...(y)...frank...:bouncy:
  6. igo1090
    igo1090 Member
    catonsville, md
    i have to put pass side in first on mine, becauseif drivers side in first, cant jack up pass side because header hits steering box.
  7. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    To install my 6901 Hooker Header on the drivers side all I do is turn the steering wheel so that the pitman arm moves out of the way ...then you can just slide the header in with ease...From the bottom of coarse.
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    whats a motor mount :hmmm:
  9. 71gold
    NO!! :eek:
    earl, didn't say that in the "instructions"...thanks a lot...i needed that...frank...:bouncy:
  10. Earl Branham
    Lugoff, SC
    Frank; that didn't work on mine. But then, I have the FlowTechs.
  11. 71gold
    well...i got the other one on tonight...took motor mount loose and jacked motor up...get plugs and wires on and it will be ready to take to the shop for tail pipes...frank...:bouncy:
  12. 74merc
    74merc computer nerd
    1974 Comet
    The more I read, the more likely I am to give away my Super Comps and put a set of 6901's on my car when I get it rolling again...
  13. Earl Branham
    Lugoff, SC
    Good job, Frank. I guess you're working this weekend?
  14. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    headers
    HMMMMMMM maybe i screwed up... everyone is using hookers-6901's... I thought heddman( 88300) was the better fit... had asked this question b4... please relieve my hesitation or confusion:huh: ... thanks in advance
  15. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    6901's fit these cars better than any header that I have ever dealt with.
    Seth
