Pick & pull 5.0 and transmission
Discussion in 'General Maverick/Comet' started by lynhrt210, Feb 4, 2017.
  1. stumanchu
    stumanchu Stuart
    Portland, OR
    First, let me pat you on the back for making your car secondary to the little ones. I also think that not selling ALL of it was a good idea. Now, if your P&Ps are like the ones near me, there are 15 v-6 explorers for every 1 v-8 car. BUT.....Mountaineers are always v8. There is no 96 mountaineer, only 97s manufactured in 96. If the engine bay is still full and you cant see the heads, check the manufacture date in the door. If it is 9/96 or earlier, chances are good for GT40 (non P) heads. Also, if you have a few to choose from, check milage.....and make sure oil fill cap has no moisture on the bottom. A look under the valve cover is always nice, but takes a little time.....but if you want a motor that doesnt scream "rebuild" you have to be a little picky. Lincoln mark VII from 87-92(?) had HO motors too, but not gt40 heads. Good Luck!!!! and happy hunting!
    lynhrt210 likes this.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Good info, didn't realize all the Mountaineers were V8.
  3. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Thank you very much. I had to put it on the back burner and when we needed money I'd sell my parts to make it thru tough times. Hopefully ill get lucky and get everything all at once if not there are two pick and pulls here that are close together
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Keep your eye out on Craigslist and LetGo as well.
  5. kunclebuc
    kunclebuc Member
    Ganer NC
    74 Maverick Grabber, 02 MB ML320, 99 Harley Fat Boy
  6. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    I've been looking on all the selling apps but I'm not finding any good deals right now..
  7. kunclebuc
    kunclebuc Member
    Ganer NC
  8. stumanchu
    stumanchu Stuart
    Portland, OR
  9. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
  10. Krazy Comet
    Dismal Swamp
    Per the tag that's a '65 intake from a 289 "A" code Mustang... Has 4J4 casting date so was cast Sept 4 1964, fairly early intake for a true '65...
  11. mvw66gt
    mvw66gt Member
    71 Comet GT
    I didn't really look that closely at it, but your right. That's an early 4V manifold. - Matt
