Pulling a Six Cylinder
Discussion in 'General Maverick/Comet' started by JackC, Jun 25, 2023.
  1. JackC
    JackC Member
    Texas
    1974 Maverck 2 door
    I'm starting to plan the removal of the 250 engine in my 74 Maverick. I have R&R'd a few engines in the past but have worked mostly with GM's until now. I understand the need to bag and tag everything, and to take pictures as I go.
    This job looks pretty straightforward, with ample room to work. I'm thinking I should detach the power steering pump and leave it in the car. Also thinking of removing the AC compressor and moving the lines out of the way. Of course fan comes off and radiator comes out.
    Wondering if I should or can try to pull the engine and trans out together or if it would be better to unbolt the trans and wrestle it out separately. Also interested in any tips there might be for wrestling the engine mounts or other aspects of this job.
    Anything folks can share with me will be appreciated.
  2. TeeEl
    TeeEl Senior Member
    Colorado
    There really isn't any "wrestling" involved.
    Drain the cooling system. Remove radiator. Disconnect fuel line, all hoses, and wiring. Remove accessories.
    Decide if you want to pull engine & trans together or just engine, which will determine whether or not you need to remove the drive shaft or unbolt the flexplate/flywheel and bell housing.
    Remove motor mount bolts (and trans mount if applicable).
    Lift the engine out...
  3. Acornridgeman
    Wisconsin
    I have always pulled and installed the engine and tranny as a unit - same time.
    BruceS likes this.
  4. Powerband
    Powerband Member
    NY's \H/
    with the length of the six and tranny be sure you have enuff equipment to get combo' almost vertical to 'pull'. Separating C4 tranny from six isn't too difficult just dont let TC slip off ...
    TeeEl likes this.
  5. Craig Selvey
    I suggest pulling both together.
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You may want to get the rear as high as safely possible to help with the angle.
    BruceS likes this.
  7. BruceS
    BruceS Member
    Texas
    1973 Comet
    What the mod and Jason said. Easy pull.
  8. CaptainComet
    What Jason said .... Pick the back end of the car up a bit and you won't have to use so much angle getting the engine out. Be sure to secure the front wheels from rolling.
    The first time I saw someone do this was a "Eureka" moment for me.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I pulled mine as one piece
    mojo likes this.
