Question about 250cid 6cyl Dist install
Discussion in 'Technical' started by Rayell, Apr 26, 2013.
  1. rthomas771
    I cut the O.D. down on my housing with a file and it still didn't fit. The housing will turn freely in the block but won't go the rest of the way in the block. I even removed the shaft from the distributor and got it to fit...so it’s not the housing that doesn't fit...it's either the shaft/gear or Hex drive.
  2. cody674
    cody674 Member
    1972 Ford Maverick
    Cardon is junk trusted me when i say this TRY A DIFFERENT ONE becoause iv had alot of problems out i went throught about 9 of them in about 2yr fyi the 170,200 and 250 all use the same dist.
  3. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    After working on it for about an hour: I came to the same conclusion. I carried it back to the parts house, and they had already sent my core back to the warehouse. They ordered another one for me with the same part number, and I will see if it fits. If not, I will get my money back, and start looking for a used one. There is not one to be found in parts stores in this area. They all special order from Cardone. The small privately owned stores even do that.:mad: BTW, they do not list one for a 1974 at all.
  4. rthomas771
  5. Rayell
    Rayell Member
    Lizella, GA
    After trying everything, I carried the darn thing back to the parts store. They reordered the same part number distributor. I got it today, and it slipped right in like it should. I installed it, and timed it correctly, now it cranks the first time a piston comes to the top.
  6. cody674
    cody674 Member
    1972 Ford Maverick
    Dont be surprized if u will have to replace it n few in mouths
  7. Rayell
    Rayell Member
    Lizella, GA
    I live day to day: I am never surprised at anything. "Where there is a will, there is a way".
  8. rthomas771
    Did you happen to notice if the shaft looked different where the Hex drive slide in?
  9. rthomas771
    He already replaced it a week later. :huh:
    I personally never had a problem with Cardone's quality...yet
  10. Rayell
    Rayell Member
    Lizella, GA
    This last one did not have that crazy insert in the shaft.;)
