Rear end gears help
Discussion in 'Technical' started by Acedmav75, Apr 22, 2011.
  1. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Don't forget to consider tire size. As an example, a 3.80 gear with a 27" tire will actually turn the same RPM as a 3.55 gear with a 25" tire.
    You can use a RPM calculator ... there all over the web. Automatics will turn a couple to few hundred more RPM due to converter slip. That is, unless your running an AOD/AODE with a lockup converter.
    I ran a 3.73 rear in a '79 stang for years behind a 4 speed 2BBL 302 and commuted about 150 miles round trip to work with no sweat. I can't remember what size tire I was running though:huh:
    I wouldn't hesitate to go 3.80 for a weekend warrior if you plan to put some "meat" on the back.
  2. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    lol i doubt ill even make it to a 22" :tiphat:
  3. FishnRace
    FishnRace Jamie
    '72 2dr 351
    I was just making the point that tire size should be considered when selecting gear ratio.
    You'd be surprised
    Some examples:
    185 70 14 = 24.2" (I think this is approximately OEM size)
    195 70 14 = 24.7"
    215 70 14 = 25.9"
    215 60 15 = 25.2"
    255 60 15 = 27"
    275 60 15 = 28" (About as big as will fit)
  4. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    thanks for the info, just confirms more that ill get the 3.55 and itll be good for what i want :drive: thanks for everything guys your awesome!
