Red Reset button, Whats up with that?
Discussion in 'Technical' started by RYS PNY, Jul 21, 2005.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    On our cars it should be the hot term and the front most small terminal on the solenoid.
  2. Jamie Miles
    Come on Rick, you ain't never used a screw driver to bump it over? Man, I been doin' that since I was in diapers. :yup:
    Ok, maybe not that long. ;)
  3. Mavaholic
    Use a tester to see if any of the wires to the switch are hot all the time. If so, you only need to run 1 wire to the small terminal next to the battery post on the starter relay. If none of them are hot, run the second wire from the battery post on the starter relay.
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Sure. 'Done that plenty o' times. I get a smiliar rush of adrenaline when I put my finger in the #1 sparkplug hole and rotate the crank to find TDC. "POOF!" :eek: :D
    Cars are cool, maannn. :drink:
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    haha I've done both of those things
    Screwdriver starter, finger compression block, etc
    I once stoled my own truck, lost the keys while out camping.
    Just ran a wire from the battery to the coil, then started it with the screwdriver.
  6. blugene
    When I wore diapers I had to use a 7/8" open wrench to bump mine over.:rofl2: Now I use a .... nevermind:D :rofl2:
    Just kiddin Jamie:p
  7. Jamie Miles
    Andy, I stoled my own Maverick the other day right outa' my own driveway basically the same way, 'cept I had to get more creative with putting it in gear with the shifter stuck in "Park" 'cuz of no key. :D
    Gene :rofl2:
    BTW: All I had to bump it over with was vice grips. :eek: :90: :p
  8. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    its nice to know things like that
