Remote oil filter
Discussion in 'Technical' started by fastback86, Jan 1, 2013.
  1. igoback70
    igoback70 Member
    IN
    70 Maverick
    Like i stated earlier,
    The Cleveland 4V and Yates HP heads have exhaust ports that are 2.00 x 1.74, these would require a 1 and 3/4 primary tube. Now unless you run HEADS that have 2.00 x 1.74 exhaust ports, you can throw duration, overlap, lift and everything else out the window cause it aint gonna matter, your HEADS wont flow what the 1 and 3/4 primary tubes are designed for.
    I'll make it simple, would you run 1 and 3/4 primary tubes on a set of heads that have 1.24 x 0.96 exhaust ports, you can mix any cam or intake you like, ?
  2. igoback70
    igoback70 Member
    IN
    70 Maverick
    That would be something to the effect of trying to shoot a spit wad through a sewer pipe.
  3. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Wow :confused: We got way off topic...putting aside what size headers are correct for a given application and why somebody needs/wants to run a remote oil filter any one else who's running one care to share installation photos? I appreciate those of you who have showed me some.
  4. olerodder
    olerodder Member
    NorCal
    Sorry, I just got carried away.................I apologize..........hope my picture may have helped.
  5. igoback70
    igoback70 Member
    IN
    70 Maverick
    Sorry Fastback, not trying to side track the thread, i was just trying to make sure Junrai knew exactally what the headers were made for. I dont want anybody spending $350 when it wont help them.
  6. fastback86
    FL
    Ah, no worries. I think I may mount my filter on the other side of the inner fender, kinda behind the splash shield.
  7. injectedmav
    injectedmav Member
    Georgia
    Not a bad idea either, just make sure it will clear your tire through full steering and suspension compression.
    97 and some 98 Expedition and F150 4X4's had a remote mounted oil filter in that same location. They are cake to change the filter and they are horizontal so they don't make a mess either.
