robs freakin sweet comet build
Discussion in 'General Maverick/Comet' started by robtech, Nov 24, 2007.
  1. robtech
    robtech has a bellybutton
    some updates...got a few parts...gonna head to the parts store in a lil bit here to see if i can get a fuel line and some other stuff...
    MSD superconductor 8.5 wires
    looks like a stock 4bbl manifold
    and the best part...lightly used 650 quick fuel carb. electric choke, vac secondaries, 67/72 jets...i love this thing, the inside is clean enough to eat off
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I run a Quickfuel carb....good stuff.
  3. Mavaholic
    Progress is always good.
  4. don graham
    watch the plug wires. i have to use the ones with a 90 on the end. if you have some that are close you might want to put the heat sleeves on them.:)
  5. stmanser
    Davenport, Iowa
    I had the same wires on my maverick. to be honest, you will have better luck with them if you use a msd 6 or 7 box, and a msd coil,
    i changed from a single point distributor to the following
    MSD Pro Billet Distributor
    MSD 6a Box (MSD 6al.. the L signifies Limiter, as in having a built in rev limiter and you can change that with a chip)
    MSD Blaster SS Coil
    MSD 8.8 Superconductor Wires.
    I spent 750 bucks from Summit Racing for everything
    I set mine at 38* at 3000 RPMS and i went .5 to .6 faster in the quarter mile.
  6. robtech
    hmm thanks i'll look into that...im reutrning those wires cuz i found them for less elsewhere...im starting to hate the only descent speed shop around here cuz their prices are horrible
  7. don graham
    i always hated using the local speed shops cause the prices were always higher. and i had to drive 60 miles. couple of years ago at the et finals in bakersfield i was having plug problems and we couldn't figure it out. two guys on our team, one being badmav7086's dad and another that owns don's hot rod shop in tucson got me straightened out. i used a set of plugs that don had and everything was great after that. won 2 track championships after that. i asked the next day what i owed him for the plugs. he wouldn't take anything for them. i ordered some from checkers after we got back. they were $5 each so he just gave me $40 bucks worth of plugs and a lot of info. i now use his shop most of the time. i think the extra cost is worth the extra benefits.:)
  8. robtech
    yea that sounds like a good speed shop...the one around here is basically just a kragens on steroids with a bunch of idiots that dont know anything. good thing summit is usually 2 days to my door
  9. robtech
    so we had my works christmas party last night...
    my boss got me a freakin b&m pro ratchet shifter :D if we're slow at work tomarrow i'll install it, otherwise i'll do it weds or friday with lots of pics.
