So I need a new radiator...
Discussion in 'Parts Interchange' started by nidus, Sep 21, 2017.
  1. Acornridgeman
    Wisconsin
    Just checked - here is the current 5% code
    RockAuto.com Discount Code for Parts & More - Expires June 5, 2018
    5% Discount Code: 4064417D8C5C02
    Expires: June 5, 2018
  2. nidus
    nidus Member
    California
    71 mercury comet gt, 75 CB550, 76 CB550
    I did end up ordering one from JEGS but it was a bit more expensive than the one from Rock Auto probably because the one I got was polished aluminum. Also you can't beat that 5% discount that Acornridgeman mentioned.
  3. 67fstbk
    67fstbk Member
    Albia Iowa
    74 grabber maverick, 67 mustang fastback
    I ordered the Rock Auto one, I hope it's correct. I forgot to try to get the 5% discout though!
  4. 67fstbk
    67fstbk Member
    Albia Iowa
    as an update, I purchased the radiator that Rock Auto shows as a V8 replacement. putting it in was complicated by the fact that the rear mounting for the fan shroud is too short. I had to get creative to mount the lower part of the shroud. Then there is the matter of the upper tank being too small, leaving a gap between the shroud. I guess it will do for now but I'm still looking for a better replacement.
  5. Acornridgeman
    Wisconsin
    That doesn't look right at all. I would contact Rock Auto and see what they have to say. They are good people to work with (at least in my experiences with them).
    That shroud is pretty useless like that for pulling air.
  6. 67fstbk
    67fstbk Member
    Albia Iowa
    I guess I can do that but it's been my experience there is no guarantee with after market fit. they never promised exact fit. It's no like I had other choices, I looked high and low.
  7. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    That looks like the factory replacement for an A/C equipped car. It’s a 3 core and need the A/C shroud to work with it.
    Acornridgeman likes this.
  8. 67fstbk
    67fstbk Member
    Albia Iowa
    so you are saying there is a shroud that will fit and it's a factory A.C. shroud?
  9. Maverocket
    Northwest
    Yes, the pic I attached is of an a/c shroud. You can see that it doesn’t stick out at the mounting points as much.
  10. 67fstbk
    67fstbk Member
    Albia Iowa
    I'm not sursure I understand. so the upper tank of AN A.C. car radiator is smaller than a non a.c. car? that s where the gap is, where the upper tank used to fill space.
  11. Maverocket
    Northwest
  12. Acornridgeman
    Wisconsin
    Man, that would be awesome if all it needs is a different shroud.
    Good eye Bob ......... :tiphat:
  13. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
  14. 71gold
    Let me check on the shroud...the radiator is ...powder coated.
