spark plug wires arcing
Discussion in 'Technical' started by 4dr73mav, Aug 17, 2005.
  1. 4dr73mav
    4dr73mav Member
    Weld County Colorado
    1973 4dr Mav V8
    I did use a timing light. The timing is now set at 12 BTDC. It seems to have a lot more get up and go. I'll have to wait to replace the wires, being a broke college student and all. Hopefully, a good set of plug wires will fix the problem.
    Thanks,
    Jonathan
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    It could still be a timing issue, or the previous bad timing could have fouled a plug.
    Check those and your plug gaps. I like my Motorcraft plugs around .42.
    You will get a different opinion on that depending on who you talk with.
    Seth
  3. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    If they are new plug wires I'd take'em back and get them replaced. Also if it's just a little bump in the idle it could just need some more tuning on the A/F mixture.
    I was helping a friend work on his 65 F100 trying to trace about the same problem. We finally found the trouble in the brand new spark plugs. They were Autolites. The plugs had a nice bright blue fuzz right where the ceramic joins the metal. I have never seen them do that but 3 were. We replaced all of the plugs with new Motorcrafts and it ran like a new truck.
    clint
  4. jim4rd
    jim4rd Member
    Yea , its cool to open the hood at nite in a dark place an watch all the flashing blue sparks . cheap thrills !!!!!Another way to check your wires , get you a fairly long screwdriver, fashion you a ground wire , clamp one end to a good ground on the engine an the other to the metal shaft of the screwdriver ( small battery cable clamps / alligator clamps ) Be careful , as your working on a running eng . Holding the screwdriver by the handle trace it over each plug wire about 1/4 inch off the wire , if you got a wire leaking / shorting out , You will see it jump the gap ,,, If you think you got a cylinder miss firing / dead , An its got ole wires on it , I use a reg. ole electrical test lite , Just ground the neg. test lead , An then on your dist . push the metal part of the tester into the top of plug wire boot on the dist.( your shorting that cyl. out ) An listen for a change in the engine if theres no diff. in the sound . Then that cyl . is not firing for some reason , bad wire . fouled plug , etc .If you got a Tach hooked up you can see how much of a drop it puts on the Eng. Sorta a poor mans cylinder balance test
