Super stock super modified article1975?
Discussion in 'Drag Racing' started by Al Martin, Nov 22, 2008.
  1. Al Martin
    Al Martin Member
    central michigan
    72 maverick
    I can remember seeing G&R branded engine parts, for sale at swaps all the time. They were common. Those days are gone now probably, havent been to a swap in 6 years, (Belleville, Mi)
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Wow
    I would have expected that intake to have more height for a drag piece.
    Any progress pics on the car, Joe?
  3. pinboss9
    pinboss9 Member
    Thank for all your help Seth (littleredtoy).
    Even though the car is in finish paint now, I won’t be able to show you the completed deal. There are plans to unveil the car to the public at an upcoming venue, along with a feature article in a magazine (Legendary Ford) when finished. So… I can’t undermine the plans that are already in motion, but I can show the progress leading up to it.
    All in all, it is a very special project that should turn out pretty nice when done, and I am thankful to be part of.
    Joe
    P.S. The seats turned out pretty nice…huh?
  4. pinboss9
    pinboss9 Member
    Being that is was the "Super Stock Drag & Illustrated Magazines Project Car", there is no less then 18 or 20 issues featuring it. The articles cover everything from race results, to modifications done to it along the way...up to Arlen's win at the US Nationals.
    Joe
  5. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    I need to research on my car, It may have been a super modified car, the shock towers havent been moved though, it also still has A/C gauges, so maybe not, it does have steel tubs on the other hand, but a nostalgia look is what I am aiming at, 347 with aluminum heads, but covered by M/T valve covers, and a Tunnel Ram, and a nostalgia paint scheme to top it off, with a dark metallic red.
    Here is what the mocked up H.O. 302 looks like
  6. 87Saleen209
    87Saleen209 Member
    Wichita, KS
    Had a drag '71 Grabber
    Feel free to post them all, lol:party3:
  7. pinboss9
    pinboss9 Member
    Hey 70ProStreet...That is a nice car. What kind of roll bar is in it? Can you post a couple of shots of the interior?
    Joe
  8. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    Yeah it has has a cage, here is a picture of the interor when i got it (Tach has to be moved lol)
    Here is a shoy of the steel tubs too.
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    70PROSTREET....this is a little off topic, but something to think about when you are putting it all together. Make sure all the switches are mounted in a spot where you can get to them "after" you are securely strapped in. When I did mine the first time, years ago, it was only after I got to the track and tightened the 5 point, did I realize all the switches where out of reach :jumping:
  10. radmav76
    radmav76 Member
    Toledo, Ohio
    1976 maverick soon to be 460 powered...project on hold.
    I did the same thing when I built my '74 mustang ll.
  11. pinboss9
    pinboss9 Member
    Al
    Hope this helps...
    This is the NHRA drag rules for that class.
    How did the body turn out... any Good?
    Joe
    SUPER MODIFIED
    Reserved for 1967 or later North American manufactured 2 door
    sedan or hardtop passenger cars of which 500 units must have
    been built and show room available with the same basic block that
    was originally available with the type of body used. Wheelbase
    103 inches or more. Body, engine, drive train, chassis, etc., may
    not be altered, modified or relocated, except as outlined in Class
    Requirements. Push starts or tow cars not permitted.
    Three classes of competition, non-supercharged. Class is determined
    by total car weight divided by total cubic inches engine
    displacement. Minimum weight in A = 3,350 pounds, B & C =
    3,000 pounds.
    DESIGNATION:A/SM, B/SM and C/SM, preceded by car number.
    Class A - 8.50 or more Ibs. per cubic inch, for big block wedge
    or canted valve engines.
    Class B - 9.50 to 10.49 Ibs. per cubic inch, for small block
    wedge or canted valve engines under 366 cubic inches
    original production.
    Class C - 10.50 or more Ibs. per cubic inch, for small block
    CLASS REQUIREMENTS
    BALLAST: A maximum of 100 pounds will be allowed but only in
    the NHRA 'accepted' weight box. See Safety Regulations, Ballast.
    BATTERY: Trunk installation permitted. Two allowed: maximum
    weight wet and fully charged, including battery box: 100 pounds.
    BODY: Must have a 2 door sedan or hardtop passenger car body
    originally produced by a North American automobile manufacturer.
    Customizing is restricted to· paint only. Body must not be altered
    in height, width, length or contour. The use of fiberglass - other
    than original production for car body used - is restricted to the
    hood. See Hood. Any other lightweight component is prohibited.
    All cars must have fully operative mechanical door handles to permit
    entry/exit from either side. Raising body and/or frame to gain
    weight transfer prohibited. Car must remain level at a standstill
    when equipped with competition rear tires, except those which have
    a forward rake, an acceptable modification. Rear rocker panel must
    not be higher than the centerline of the rear axle. Removal of
    body parts, fender panels or bracing is not permitted. All body
    panels must be stock, acid dipping or other lightening is not
    allowed.
    BRAKES: Must be equipped with stock production four-wheel hydraulic
    brake system installed at the factory. A heavier rear-end
    housing may be used complete with brakes for that application.
    BUMPERS: Complete stock bumpers, guards and braces both front
    and rear are required.
    CARBURETOR: Limited to one 4-barrel American automobile carburetor
    of 850 CFM in A class. B & C classes are restricted to 750
    CFM rated capacity as accepted by NHRA. No internal or external
    machine work allowed except float bowl modifications. Choke plate
    and linkage may be removed.
    CYLINDER HEADS: Production line installed wedge or incline valve
    heads only, ports may be matched to intake manifold but must not
    exceed 1fz inch depth. Sandblasting, bead blasting, porting, polishing,
    welding and exhaust port plates prohibited. Over-size valves
    may be used, but stem size and valve guide location must remain
    stock. Valve seat area may be opened or machined for larger
    valves but not to exceed 1 inch in depth from bottom of valve
    seat. Combustion chamber modifications acceptable. Heads may be
    ground for larger push rods.
    DRIVELlNE: May be modified or fabricated to fit altered units. See
    Safety Regulations, Drivelines.
    DRIVER: Must be in stock location. Revision of seat location prohibited.
    ENGINE: The basic block must have been available in the type of
    body used. Displacement unlimited in Class A, limited to 366 cubic
    inches original production in B & C. Engine set back or raising
    engine prohibited. Any internal engine modifications allowed. See
    Cylinder Heads. Dry sump oiling systems not permitted.
    EXHAUSTSYSTEM: Open exhaust with headers, permitted. Tailpipes
    and/or mufflers optional. Outlets for open exhausts cannot exceed
    4 inches in diameter.
    FENDERS: Front and rear fenders may be opened for larger tires.
    All parts of the tire tread and wheel rim must be inside the stock
    body or fender lines. Flaring or bulging fenders for wider tires is
    prohibited. All opened or radiused fenders must be re-rolled.
    FENDERSPLASH PANS: Must be retained, cannot be removed, but
    can be trimmed to allow a maximum of 2 inches clearance around
    headers. Shock or spring towers may not be altered.
    FIREWALL: Must remain stock, no alterations of any type permitted.
    flOORBOARDS: .Stock with exception of shifter installation. Removable
    floor for transmission installation restricted to 6 square feet
    made of steel identical to area removed. We recommend cutting
    floor from another car to replace area cut out.
    FLOOR: Stock floor required. The area from the front shackle of
    the rear spring to the rear of the trunk may be sectioned in width
    to allow narrowing of rear frame. Cutting into stock floor for suspension
    members not allowed. Any protrusion in the trunk may
    not be higher than the top of the stock frame rail. Cover must
    be made of materials of 14 to 20 gauge. No thinner than 20 gauge
    and no thicker than 14 gauge.
    FLYWHEEL/CLUTCH: Use of stock type, cast iron flywheels and/or
    pressure plates , prohibited. Explosion·resistant units required.
    FIlYWHEELSHIELD: SEMA 6-1 flywheel shield required on all stick
    shift transmissions. Minimum requirement for automatic transmissions
    is an accepted flexible blanket shield. See Safety Regulations,
    Flywheel Shields.
    FRAME: Must be stock automobile frame for car body used. Properly
    reinforced stepped stock frame accepted. Rear frame may be
    moderately moved in for tire clearance. Rear sub-frame may be
    constructed of 2" X 3" rectangular material with .120" wall thickness
    and must be installed at the original height location. Cross
    members may not be altered or relocated except as required for
    transmission swaps, shock absorbers and traction bar installation.
    Front-to-rear frame strengthening members may be added to any
    unibody constructed car, they may be up to 2" X 3" material with
    .120" maximum wall thickness located in a straight line between
    front and rear sub frames. If material passes thru floor, the floor
    must be welded to' the member leaving no holes in the floor.
    FUEL SYSTEM: Original stock-type fuel tank mounted in stock location
    must be used. The use of a fuel cell is acceptable, 15 gallon
    maximum. Electric fuel pump may be used. If filler neck is relocated
    into the trunk the tank must have a pressure cap and tank
    must be vented to the outside of the body. Trunks must then be
    completely isolated from the driver and passenger compartment
    with a suitable firewall of flameproof material. Tank may be
    notched or sectional for suspension clearance. Fuel blocks accepted.
    See Safety Regulations, Fuel Systems.
    GRILLE: Grilles must be stock production for body used.
    HELMET: Required. See Safety Regulations, Helmets & Goggles.
    HOOD: Required. Fiberglass hoods may be used. Carburetor must
    be completely covered by hood, a bubble, or a scoop which must
    be a part of the car's hood. Hood latches, hinges, springs and
    brackets may be removed. A maximum of a 5 inch hood scoop
    with one opening may be used. Tilt or removable front end not
    permitted.
    INSTRUMENTS: Stock dashboard, including instruments must be
    retained, Optional instruments (tachometer, pressure gauges, etc.)
    are permitted.
    MANIFOLD: A single 4 bbl. manifold produced by a recognized
    manufacturer in a quantity of at least 100 and accepted by NHRA
    must be used. Cast iron or cast aluminum alloy must be used.
    No external modifications permitted except adding spacers for
    carburetor or machining top of manifold to lower carburetor.
    RADIATOR: Full size stock radiator required for type of body used,
    with stock water pump for type of engine used.
    ROLL BAR or ROLL CAGE: Mandatory in all cars. See Safety Regulations,
    Roll Bar or Roll cage.
    REAR END: Must use stock type rear end. Ratchet type (limited
    slip) or locked rear ends accepted. Quick-change rear ends not
    permitted. No welded spiders allowed. Four-wheel drive cars not
    permitted, The use o,f two speed rear ends is not allowed.
    SAFETY BELTS: Required. See Safety Regulations, Safety Belts.
    SPOILERS: Must be automotive production items for car body used.
    Complete package, front and rear, not required.
    STREET EQUIPMENT: Horn, windshield wiper assembly, charging
    system, sway bar, emergency brake, heater and wiring harness may
    be removed. It is suggested the lighting system be operational.
    SUSPENSION: Must retain complete stock front suspension system
    as produced by the manufacturer on the assembly line for the body
    used. Front suspension, body and frame must be of the same
    year, make and model. Rear suspension must be same type as
    factory produced. Leaf springs on leaf spring equipped cars, coil
    springs on coil spring equipped cars. Must use stock type mounting
    methods including rear spring shackles on leaf spring equipped
    cars. In addition to stock suspension a pivot below the rear axle
    housing will be acceptable. Chopping and/or machining of any
    chassis or suspension component is prohibited, At least one shock
    absorber must be used for each wheel. Rear shocks and springs
    may be moved in-board for tire clearance. Coil over shock units
    not allowed. Minimum travel on shock absorber: 1 inch. All lift
    kits must be identified with "Meets SEMA Specs 9-1". Suspension
    components, including traction bars, may not extend through the
    original floor of the car. The interior floor must remain as originally
    produced as to contour and material.
    TIRES: Rear tires are limited to 101/2 inches wide x 30 inches
    diameter when new. Accepted tire sizes will be listed in National
    Dragster, Inner wheel wells may be altered but must be completely
    finished as originally produced. See Fenders and Wheels for restrictions.
    TRACTION BARS: Traction bars or similar devices used to transmit
    real axle torque to the frame, thus preventing violent rearspring
    wind-up under acceleration or deceleration, are considered
    safety equipment and are therefore highly recommended. However,
    units must not be longer in overall length than one-half
    the wheelbase of the car. Traction bars and/or mounting brackets
    to the rear axle housing must not be lower than the lowest edge
    of the rear wheel rim. The use of wheelie bars is not acceptable.
    TRANSMISSION: A clutch must be needed to shift all gears in a
    conventional stick-shift manner. Any aftermarket conventional clutch
    operated 4 speed is acceptable. Automatic transmissions may be
    clutch assisted. Must have a reverse gear. Overdrive units are
    not allowed.
    UPHOLSTERY: Full interior trim must be retained according to
    factory specifications. Must run stock front seatts), rear seat
    optional if area is upholstered and a roll bar installed.
    WEIGHT: Any item added to car as a safety device must be for that
    specific purpose. Disguised ballast is not permitted.
    WEIGHT DISTRIBUTION: Not more than 50% of the total weight
    of the vehicle - with driver - may be on the rear wheels.
    WHEELBASE:All cars must retain stock Wheelbase and tread width
    for car body used. Minimum wheelbase: 103 inches. May have no
    more than 1 inch variation in wheelbase from one side of the car
    to the other.
    WHEELWELLS,Rear: Internal modifications only. Flaring or spreading
    of external fender lines is prohibited. Minimum wheel diameter
    14 inches, unless original factory equipped with smaller units.
    If internal wheel wells are modified the outside of tire tread must
    be within 2 inches of fender. Any material used to add to the width
    of the inner wheel wells must be o·f the same material and thickness
    as original.
    WINDSHiElD/WINDOWS: All windows, wlndshields and backlite must
    be clear except for factory tinted safety glass and in good condition.
    Windows must be closed during competition, need not be
    operative. Identification decals not permitted on any window,
    windshield or backlite.
