The best engine oil
Discussion in 'New Members Forum' started by LEATHERFACE, Feb 1, 2010.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The oil pump is driven by a shaft that goes into the bottom of the distributor. I have seen quite a few of these shafts twist in half. I would pull the distributor and verify this first.
  2. LEATHERFACE
    LEATHERFACE Member
    Union Valley, Texas
    1964 Mercury Comet Caliente
    1964 Mercury Comet Caliente / 260
    Well, I considered all the suggestions and went with Mobil 1 oil and Wix filter. The oil pump priming shaft was the actual problem as the pic shows. Just twisted in half. I went ahead and replaced the oil pump since you have to drop the oil pan to get to the shaft. To do that I had to chop off some exhaust pipe, which wraps around the pan. I'm gonna put duels on it anyway (son's car). I also had to jack up the engine from the mounts to clear the pan. Cleaned it up, replaced the parts, put everything back and it runs like a dream. I'll put up some video soon as I get the timing perfect. ha ha.. Anyway, almost there. I'll keep posting updates.
  3. justin has a 74
    kentucky
    That shell oil is pritty good. i just cant remeber what its called.
